Autodesk VIZ Autodesk VIZ
Old April 22nd, 2008   #1 (permalink)
RBA
Name: Ruud van Aerde
Netherlands
Default importing a dwg in 3ds smooth
Hi,
I want to import a .dwg in 3ds, but the curves are not smooth in the 3ds model. Also when I render the scene it is not smooth. The CAD model is near the 0,0,0. I think it is a problem importing the file in 3ds, but what is the problem?
I use 3ds VIZ 2006 and ADT 2005.
Thnx,
RBA is offline
Old April 22nd, 2008   #2 (permalink)
RBA
Netherlands
Default Re: importing a dwg in 3ds smooth
I have found the answer myself. The surface deviation (by importing the file) was to high (25,4), put it to 0,01 then the surface is smooth after importing the .dwg.
RBA is offline
Old April 23rd, 2008   #3 (permalink)
Ireland
alternatively you can smooth out the faces in Viz using the smooth modifier, or the smooth tools in the edit mesh modifier.
Hobo Monstrocity is offline
DWG to 3DS Max problem christr 3ds Max 13 April 3rd, 2008 10:59 AM
Autodesk 3ds Max 2009 and Autodesk 3ds Max Design 2009 Now Shipping Jeff Mottle 3ds Max 25 April 1st, 2008 05:58 PM
Text missing when importing a DWG file into 3dsmax eMirage 3ds Max 3 November 22nd, 2007 09:42 AM
Importing CAD models into 3ds Max 7 bover 3ds Max 1 October 10th, 2005 09:51 PM
importing DWG in 3ds max jasonlg3d 3ds Max 9 May 28th, 2005 11:21 AM
