Old April 26th, 2008   #1 (permalink)
manta's Avatar
Default water level
Hey MR experts...does anyone know of an equivalent to vray's water level setting in its displacement...I thought I was on to something when I checked "cutout" in the A+D material... but there wasn't any way to adjust it...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old April 27th, 2008   #2 (permalink)
Justin Hunt's Avatar
Default Re: water level
Cant give you any hints for the displacment, but for cutout, think of cutout as opacity mapping on steroids. In actual fact it acts as a pass through instuction for the rays. Hence works much better than normal opacity mapping.
What does the water level do, is it something to do with the base height of the dispacement?
jhv
Justin Hunt is offline
Old April 27th, 2008   #3 (permalink)
manta's Avatar
Water level is clipping, you specify the depth, and what is below that, is cut. In this case, the black areas, so in this wicker texture , you can see through it...
DESIGN FORWARD
manta is offline
Old April 28th, 2008   #4 (permalink)
MasterZap's Avatar
Name: Håkan Andersson
Sweden
Talking Re: water level
You can do this.
You simply put the displacement map also into the cutout map. What you WANT do to is to threshold the cutout map.
Just do what you did, but with one addition: For the cutout, pipe the displacement map through the "Output" shader, and set a curve with a sharp discontinuity on it. It should look like a stairstep, with everything below a certain level should be 0, and everything about that level should be 1.
/Z
MasterZap is offline
C4D WATER SHADERS STRAT Cinema 4D 28 October 2nd, 2006 03:42 AM
Help me with this water AJLynn Cinema 4D 9 November 14th, 2005 09:51 AM
Water Fountain - need the Water vizwhiz Autodesk VIZ 5 February 9th, 2005 10:34 AM
Liquid Cooled Systems?!! Erik Lund Hardware and Technical Discusions 6 July 9th, 2002 10:22 PM
