Old May 3rd, 2008   #1 (permalink)
Name: Tiago da Silva
Japan
Default Setting up the light intensity in the physical sky
Hi there,
is there any way to diminish the sunlight intensity in Maxwell's physical sky settings? My image is saturated due to the sun being too bright...
Thx in advance
trcsilva is offline
Old May 5th, 2008   #2 (permalink)
Maxer's Avatar
Default Re: Setting up the light intensity in the physical sky
Yes change you camera settings (f-stop and shutter speed), the physical sun has no intensity adjustments except for what time of day it is.
“There is no spoon”
Maxer is offline
Old May 8th, 2008   #3 (permalink)
markus groeteke's Avatar
Germany
you can also influence the sky luminance intensity when rendering in multilight mode.
cheers
markus
3dworks visual computing - berlin, germany
www.3dworks.com
click here for more images
markus groeteke is offline
Old May 8th, 2008   #4 (permalink)
Japan
Thx guys. I also figured out that, if I use a darker version of my texture, it ends up with the tone want.
trcsilva is offline
Vray physical sky question Tommy L VRay Render 4 January 31st, 2008 07:12 AM
Physical sky & camera with internals.. alfienoakes General Discussions 2 January 17th, 2008 12:00 PM
Internal Lighting With Vray Sky / Sun & Physical Cam JamesTaylor VRay Render 25 September 17th, 2007 09:56 PM
animation & light intensity problem harrowboy 3ds Max 3 August 7th, 2006 05:40 AM
Sky light doesnt count !!? Hozz 3ds Max 0 August 1st, 2005 03:51 AM
