Old May 7th, 2008   #1 (permalink)
Trevor Tizard's Avatar
England
Default looking for illustration software
Hi,
I'm looking for a piece of software that will take the bucket fill feature of MS Paint to the next level. Basically I want to import a line drawing (in some form of bitmap or jpeg) and bucket fill areas as I can in paint. However I want to be able to fill with paterns/bitmaps for wood, floor tiles, worktops etc. These patters should be both scaleble and rotateable. Ideally I'd like to have a library of fills to use.
In essence I want to take a bitmap of a kitchen perspective view and add finishes to the doors, worktops, floor.
Anyone have any suggestions.
Trevor Tizard is offline
Old May 7th, 2008   #2 (permalink)
STRAT's Avatar
Wales
Default Re: looking for illustration software
photoshop elements
STRAT is offline
Old May 7th, 2008   #3 (permalink)
aaron-cds's Avatar
In photoshop, you can bucket fill areas. For your floor layer that you bucket fill, you can then use the pattern effect to replace the solid color bucket fill with a bitmap that you can scale and rotate.
Aaron Coon, Conceptual Design Studio
aaron-cds is offline
Old May 7th, 2008   #4 (permalink)
England
Thanks to you both,
However, am I right in thinking I'd have to define my wood or tile texture as a pattern to bucket fill, and if so how do I then rotate and scale it?
Old May 7th, 2008   #5 (permalink)
aaron-cds's Avatar
Originally Posted by Trevor Tizard View Post
Thanks to you both,
Yes, but it's probably not that difficult. You can scale it in the effects menu for the pattern fill. You can rotate it by rotating the bitmap itself, just guessing.
Old May 8th, 2008   #6 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
use a layer mask and a large pattern fill behind it then use the free transform (holding control on the corners when moving) to make it match/skew.
Antisthenes is offline
Software Development Sawyer General Discussions 0 April 21st, 2008 11:26 AM
About time garethace Hardware and Technical Discusions 19 September 12th, 2007 08:33 AM
Photo Recovery software for Mac Users unsolicited General Discussions 0 September 14th, 2006 06:24 AM
Anyone actually try out Alibre Design Xpress 3D software? Hazdaz General Discussions 1 January 16th, 2006 11:40 AM
Software forum? I need some software... Cesar R General Discussions 3 October 27th, 2004 06:45 AM
