Old May 8th, 2008   #1 (permalink)
nodar1978's Avatar
Netherlands  Send a message via Skype™ to nodar1978
Default using materials
guys maybe stupid question, but what is best way, if you have lots of materials in scene and mtl editor window 6x4 is not inough? I'm using pick material fro object and then changing and ..., but maybe there is an easier way? thanks
nodar1978 is offline
Old May 8th, 2008   #2 (permalink)
mattclinch's Avatar
England  Send a message via MSN to mattclinch
Default Re: using materials
i use the 'get material' button and then select 'from scene' and choose one. gotta have them nicely named obviously.
Matt Clinch
Arch Viz Artist @ Hayes Davidson
http://www.hayesdavidson.com
mattclinch is offline
Old May 8th, 2008   #3 (permalink)
nodar1978's Avatar
Thumbs up Re: using materials
thank you, exactly what i wanted
thanks
Old May 8th, 2008   #4 (permalink)
louis.cho's Avatar
Name: Louis Choinière
It's a shame that autodesk make it 6x4 max.
I all my scenes use way much materials. They should be displayed 6x99 with a slider!
______________________
Louis Choiniere
www.espaceparallele.com
louis.cho is offline
Old May 8th, 2008   #5 (permalink)
Justin Hunt's Avatar
No need for more, 1 or 2 is more efficient, uses less memory too.
Dont forget that you can drag and drop a material from one slot to another to copy it. just remeamber to rename the copy
A often over looked tool is the material library
jhv
Justin Hunt is offline
Old May 10th, 2008   #6 (permalink)
nodar1978's Avatar
thanks guys
Why Do My A&D Materials Do This? renderhaus 3ds Max 3 February 14th, 2008 07:44 AM
Xref materials martindrake81 3ds Max 0 November 15th, 2006 07:29 AM
Assigning Materials with Maxwell in Max Ricardo Borges Maxwell Render 5 July 18th, 2006 10:56 AM
quickly changing multiple materials ahuygen Cinema 4D 2 October 11th, 2005 05:45 AM
Materials forum... Tonsgaard Suggest a New Forum 0 August 19th, 2003 01:42 AM
