Name: Tom Livings |
I have an object that is animated to follow a path constraint over 90 frames. I would like to render a single frame which shows the object in all 90 of its positions. Im sure its possible, anyone know how to do it?
Thanks, Tom. Oh, Im using 3d studio max 2008 and vray.
Name: Tom Livings |
The problem is the object is scaled over the 90 frames also. Im using animation because I need to scale the object as it repeats along the spline.
Its actually for a train track seen from above that becomes smaller as it goes along. This isnt as easy as it sounds, The ties have to get closer together, scale down and follow the spline. Any ideas?
You can use Tools/snapshot with range from 0-90 and make 90 copies
http://www.vnimation.com/ |
Name: Tom Livings |
Brilliant, thanks Dinh.
| Animation #3 (Apartment in the four-storey house exterior and interiors) | PixelRendering | Finished Work | 7 | August 1st, 2007 07:03 AM |
| vray animation.. | shikodesign2000 | VRay Render | 3 | December 15th, 2006 07:12 AM |
| Animation in VRAY flickering? | charadesia | VRay Render | 2 | June 3rd, 2006 02:46 AM |
| Animation Help | steven martin | General Discussions | 0 | July 15th, 2005 01:51 AM |
| executive wing animation | crazy homeless guy | Work in Progress (WIP) | 30 | June 21st, 2004 03:20 PM |
