3ds Max Autodesk 3ds Max
Old May 13th, 2008   #1 (permalink)
United_States  Send a message via AIM to ericbarlow21 Send a message via MSN to ericbarlow21
Default Hopefully this may help you if you are having timeout issues with Backburner:
Hello All,
I know that some people are having issues with Backburner timing out on renderings, or not saving their settings. I just wanted to share a couple of our solutions incase you are experienceing these issues:
(assuming you are upgrading from Max 9 --> 2008 or 2008 --> 2009)
1.) completely uninstall the old backburner, and install the new one included with the new version of Max you are installing (even though they may be the same version or list no changes in the release log). I am not sure why, but making this change has been the difference in working correctly vs. not working in regards to our timeout issues.
2.) we once had issues with Backburner when upgarding to Max 2008, because our manager was running on 32 bit while 64 bit was being used on within our farm. Even though our manager is a 32 bit system, using the 64 bit software solved our issues. i dont know why, but it did.
Anyways, I know these solutions worked for us, so if you are having problems, you may want to give them a try.
Good luck!
ericbarlow21 is offline
Old 3 Weeks Ago   #2 (permalink)
nicnic's Avatar
Default Re: Hopefully this may help you if you are having timeout issues with Backburner:
arrghhh this is such a pain in the ass
Iv tried everything...nearly. it used to work until last week when *something* changed on the farm and now it wont render past 600 mins
I hate you autodesk, this has been intermittently broken since 2006 and i have read every thread on the subject everywhere and no guaranteed fix.
Just wanted to say i hate you, in person.
nicnic is offline
Old 3 Weeks Ago   #3 (permalink)
BrianKitts's Avatar
It's always been backwards with Autodesk to avoid timeouts.....you have to enable task timeout in the advanced settings (yes I mean turn it on) and then set it to a high value, (max is 70000) minutes..... to keep it from timing out.
leaving the task timeout disabled has never worked well.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old 3 Weeks Ago   #4 (permalink)
nicnic's Avatar
ah but my problem over this last weekend was that I was manually entering 2500 min (plenty enough time for my render) but it was timing out at 600 anyway. I think it has to do with having 32 bit max alongside 64 on my machine, well thats my theory until 7pm anyway.
i solved it by taking over the whole render farm and using DR today, just lucky nothing else was on
thanks.
nicnic is offline
Old 3 Weeks Ago   #5 (permalink)
Brian Cassil's Avatar
I've encountered this problem many times over the last couple of years. I've done everything suggested here and last night a job timed out after 600 minutes. Seriously, can this be so hard to fix!?
"writing notes is quieter."
Brian Cassil is offline
More Backburner issues Timothy Saunders 3ds Max 18 March 29th, 2008 05:47 PM
Backburner Job Share Thox 3ds Max 0 May 23rd, 2007 03:25 AM
Backburner & IP Address Brolloks Autodesk VIZ 2 October 18th, 2006 07:29 AM
URGENT: BackBurner issues: random picking order?? nisus 3ds Max 7 April 25th, 2006 04:43 PM
Backburner timeout error Chad Warner Autodesk VIZ 14 July 6th, 2004 07:35 AM
