Name: Steve Gruesen |
i feel like a dork for not looking this up before i "need" it, but why can't i get rgb values in an arch&design diffuse color swatch when i click on the color selector? for instance 192 red is what decimal value? must be a way to change it?
thanks |
Name: Joel Callahan |
Yes.
Open your material editor get your a&d material slot 'ready' open a 'blank' generic (non-A&D slot next to it) click the diffuse colour to enter the RGB values in the blank generic slot ok - the colour is now set. right-click the diffuse colour and then pick copy click and select the A&D shader material slot right-click on the COLOUR slot under the MAIN MATERIAL PARAMETERS rollout at the top and select paste ta da |
Name: travis schmiesing |
I believe the A&D materials only work with floating point color settings. I haven't done any more research than that.
travis schmiesing |
yeah that's about all i know so far. otherwise i was thinking some neat way to convert using 255 as a base number or something
Name: Brian Bradley |
Hi Steve,
Don't be fooled into thinking that your A&D shader colour swatch is 'only' a decimal version of the standard. The fact that the A&D is a true HDR shader means you have Ultimate control over all aspects of a surfaces properties, including colour variation. The number of colours available using the A&D's floating point numbers are masive compared to the standard material. This IS the way forward for CGI. May take a bit of getting used to, but you honestly NEVER want to go back to a limited 0-255 colour pallette. Regards Bri
Hit Ctrl-N with the spinner highlighted.
This will pop up a window where you can enter mathematical expressions which will be pasted to the spinner on completion. type (yourvalue/255.0) to convert 8-bit to float, or (yourvalue*255) for the other direction. |
| white balance RGB VALUES | sanjay_chaphekar | VRay Render | 4 | January 26th, 2008 01:08 AM |
| Ral classic to Rgb color converter | gdrakakis | Cinema 4D | 3 | May 7th, 2007 02:14 PM |
| Quiestion about IOR values .... | yogeshwagh | VRay Render | 10 | August 6th, 2006 02:37 PM |
| rgb values and advanced lighting - viz 4 | 3dway | General Discussions | 0 | January 9th, 2004 06:47 AM |
| PANTONE colors - Need RGB values for VIZ | Eric | General Discussions | 3 | October 12th, 2002 08:00 AM |
