Old May 17th, 2008   #1 (permalink)
Default render pass problem
so when i render out using mr passes, all my passes look great, but then when i merge i get this odd problem with my hedges. they are a scatter object. it only happens when i merge the building behind them. if i render just the foiliage pass, fine. if i render another building in the scene, fine. it's just when i merge the building behind these hedges. i've delete and recreated on a new layer, same thing.
any ideas? thanks.
EDIT: the odd problem is, it appears as if i lost 1/2 of my leaves. in the other renders they are thick and you can't see through them.
SgWRX is offline
Mental Ray render problem winterlight 3ds Max 7 August 22nd, 2006 09:57 AM
request to criticise the work anindia Work in Progress (WIP) 4 April 5th, 2006 02:47 AM
Final Render Problems Maxer finalRender 5 November 10th, 2004 08:30 AM
problem render to AVI HAIDORY 3ds Max 2 November 1st, 2004 04:08 AM
