Old May 20th, 2008   #1 (permalink)
Name: vijaya venkatesh
Default problem in daylight with fg
Hi.............I have a great problem in using daylight with mental ray. please somebody help me. I created an exterior scene in 3dsmax8 and set a daylight with intensity value 1. I also enabled global illumination and final gather with default values. And in environment settings I select logarithmic exposure control.Another important thing is materials. Ya....... in materials also I applied only architectural materials. But finally it looks very shabby and patchy. Please help me to produce a photorealistic output. Please check my works and tell what will be mistake. In attachments, one image is with daylight and final gather. Another one is scanline with m area omni light.
3d artist is offline
Old May 30th, 2008   #2 (permalink)
Name: Novel Hernandez
Default Re: problem in daylight with fg
Try using the mR Daylight system. Then set your exposure to "mR photographic exposure control" and set it to outdoor daylight. Use Final Gather set to Draft and no GI at first. Try that and post your results.
novelh is offline
Old May 30th, 2008   #3 (permalink)
manta's Avatar
I don't think he has those things...he's using max8...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old June 1st, 2008   #4 (permalink)
SandmanNinja's Avatar
vijaya,
It's a lot EASIER to make photorealistic renders with the newer versions of Max and Mental Ray. There's A&D materials which have Ambient Occlusion built into them, and they just look better than the other materials.
Heck, in Max 2009 there's Pro-Materials which are supposed to be even better (but I haven't seen it yet).
I don't have any tips for you for Max 8.
-SandmanNinja
website
SandmanNinja is offline
Computer Problem? Need Help? Check Here First! Greg Hess Hardware and Technical Discusions 7 August 22nd, 2008 04:38 PM
Mental Ray/Image Based Lighting & the Daylight System? Brad_S Mental Ray 4 January 30th, 2008 03:13 PM
Bitmaps....mental ray....daylight study xeunox Mental Ray 13 October 3rd, 2007 02:55 PM
Video Card problem? Jeff's Friend Hardware and Technical Discusions 12 September 11th, 2003 04:33 AM
