Old May 27th, 2008   #1 (permalink)
Default Benefits of EXR's?
Hi Guys,
I understnad EXR files are open source and all, but Im not sure exactly what that means.
What exactly are the benefits of saving as an 'open source' file over a standard tiff or png?
I was reading (vismasters?) that you can use it to control the exposure between environments, i.e. In an external scene to make the interior brighter and vice versa?
Cheers!
selos69 is offline
Old May 27th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: Benefits of EXR's?
Just a quick note to an Aussie mate...
As far as I know, EXRs are like HDRs - 32-bit and they have values greater than "1" or "255" (whatever the scale is), so they "emit" light. So you can use them just like an HDRI file.
I usually split my HDRs into two areas - HDRI - Environment and HDRI - Lighting.
I, too, await more cogent replies.
-SandmanNinja
website
SandmanNinja is offline
Old May 27th, 2008   #3 (permalink)
Trevor Tizard's Avatar
England
http://en.wikipedia.org/wiki/OpenEXR
Trevor Tizard is offline
Old May 27th, 2008   #4 (permalink)
shaneis's Avatar
Originally Posted by selos69 View Post
Hi Guys,
It means that the source code for the file format it publicly available, so if you feel like developing plugins, software etc for EXR, you can do so.
Cheers!
openEXR was developed by the good folks at ILM. One of the main day-to-day benefits of openEXR over other high dynamic range formats is that the file size is much smaller. To loosely answer your question about PNG or 8-bit TIF, they are low dynamic range, in other words, limited in how much tonal data can be stored in the file compared to EXR, for example. Think 256 possible tonal values for a pixel as opposed to 4,294,967,296. Hmm, better! This also explains why blacks and whites are clipped/ clamped in 8-bit files, and why banding artifacts appear in grey tones.
All this is hard to tell when looking at a monitor - 16,777,216 combinations/ iterations (remember the "16 million colours" option for CRT monitors?) or converted to just over 10 million on a top-notch LCD with a 12-bit LUT... this is why CRT's are still preferred for colour work.
As a side note, float data, calibrated monitors, gamma-corrected images/ cameras, RAW colour-clip...all this linear data comes together in the simple-yet-messy-knot that is LWF.
Long story short - don't use anything less than 16-bit while you're working, preferably 32-bit, always keep an original in 32-bit and convert a copy of the original image to 8-bit when you're finished. EXR's are great for this 'cause they're smaller on-disc.
Originally Posted by SandmanNinja View Post
...As far as I know, EXRs are like HDRs - 32-bit and they have values greater than "1" or "255" (whatever the scale is), so they "emit" light...
They have values outside the 0-255 range in both +ve and -ve directions... "whiter than white, and blacker than black", perhaps? Or not unlike the visible spectrum compared to the entire electromagnetic spectrum.
For more info on openEXR, check http://www.openexr.com/ and for more info on floating-point, 32-bit vs 16-bit vs 8-bit et al, Wikipedia will answer all your questions and more.
S.
shaneis is offline
Old May 27th, 2008   #5 (permalink)
AJLynn's Avatar
There was a very good presentation by some Neoscape guys at a Boston user group meeting last month. (Any Neoscape guys listening? The web site has videos of the presentations on particles but not the ones on EXR...) It had nothing to do with it being open source, which doesn't really factor into daily use, but they demonstrated how to use Photoshop to see the quality of the color information in an image, and how bad JPEG is, how PNG is better, 16-bit is better than 8-bit and 32-bit is best of them all. It lets you work with the exposure in ways than non-high-dynamic-range formats don't - because of the ability to do super white, for example, if you've got parts of the image that are overexposed that would just be white in a normal image, in HDR you can drop the exposure and see the detail. Also, in my experience when you start messing with things like levels, in an 8 bit format you lose quality very quickly, so I don't work in anything less than 16 bit these days.
AJLynn is offline
Old May 27th, 2008   #6 (permalink)
nicnic's Avatar
You can also embed channel info into exrs, zdepth, specular, reflction, ao etc
You need the ProEXR plugin to use these channels in photshop/after effects however, but Shake and Fusion support it out of the box.
Its really handy for embedding all your passes into one file.
nicnic is offline
Old May 27th, 2008   #7 (permalink)
full float format with pretty good compression.
percydaman is offline
Old May 27th, 2008   #8 (permalink)
shaneis's Avatar
If you run OS X or a Linux distro, Cinepaint also supports embedded channels in openEXR. Blender (all OS) supports same.
http://www.cinepaint.org/
http://www.blender.org/
S.
shaneis is offline
Old May 27th, 2008   #9 (permalink)
Cool, Im understanding it now. Thanks guys!
1 more question though, and the reason I couldn't be bothered using EXR's till now is how do I apply filters that have been dissallowed in photoshop?
selos69 is offline
Old May 27th, 2008   #10 (permalink)
AJLynn's Avatar
You'll need to do all your 32-bit stuff then convert to 16-bit before continuing.
AJLynn is offline
MR Animation Exposure EXR's ? Spacelord Mental Ray 0 February 27th, 2008 06:30 PM
Windows Vista benefits? RyanSpaulding General Discussions 14 February 3rd, 2007 09:45 AM
