Name: Joel Callahan |
I think you should consider some tutorials.
The basic idea would be to render out to a series of still images (not JPG, as they are compressed - TIFF, BMP, TGA, etc would be fine). Then load them into Ram Player and save it out as an AVI. There are a lot of other things to consider, but this should get you on the road to exploring. |
Yep, render out the sequence or series to an image format instead of avi, and then put together in an editing program. If you're using adobe premiere, for example, import the first image file, and make sure to tick "image sequence" underneath it in the import file dialogue window. Then render the sequence of images to an avi.
very simple really. But as Sandman said, i would not use jpg, since they are compressed and will result in a low quality avi when assembled.
"Well I figure it has to be bigger than smaller. Whats the point of designing a concept the size of a hot dog stand? J.G. |
render out as .tif
then download, videomach, and load your tiff sequence into that and it will export an .avi for you, all uncompressed so you will lose zero quality. Videomach is much quicker than any other software i have seen. if you want credits and transitions then it is no use, all it does is convert image sequences into an .avi file |
| Animation #3 (Apartment in the four-storey house exterior and interiors) | PixelRendering | Finished Work | 7 | August 1st, 2007 07:03 AM |
| What is the best setting for animation using VRAY? | cxdesigner | VRay Render | 2 | July 13th, 2005 01:14 AM |
| File Link Problem... | demo38 | 3ds Max | 0 | April 13th, 2005 10:50 AM |
| Final Render animation problem | Maxer | finalRender | 8 | August 18th, 2004 01:05 PM |
| Viz4 Animation Jitter/Flicker Problem | jbennett134 | Autodesk VIZ | 6 | March 25th, 2004 09:39 AM |
