Old May 29th, 2008   #1 (permalink)
Default Best cpu config?
Hi folks,
We using windows xp family edition sp3 with max 2008 x32 and we would like to change versions of max and windows to get the maximum performance.
Here's the system spec :
Intel core 2 quad q6600 2.40 ghz
2go ram ddr2
nvidia geforce 8600 gts
Is windows xp pro x64 with max 2009 x64 should be the best option?
We using this cpu for hires 3d modeling, animation and rendering (vray)
bombacool is offline
Old May 29th, 2008   #2 (permalink)
AJLynn's Avatar
Default Re: Best cpu config?
You can go to XP64 with that system. And upgrade the RAM to 4GB.
AJLynn is offline
"System Failed CPU Test" JamesTaylor Hardware and Technical Discusions 8 April 16th, 2007 01:53 AM
LSNet on DualCore CPU??? HOW?? okmijun Lightscape 0 June 1st, 2006 05:06 AM
Setting up a low cost Render Farm using old CPU pradipta Hardware and Technical Discusions 5 November 23rd, 2005 12:04 AM
dual CPU issue Beno Hardware and Technical Discusions 3 April 6th, 2004 07:58 AM
New Lo-noise 80mm CPU coolers garethace Hardware and Technical Discusions 13 December 18th, 2003 10:41 PM
