Name: moos a |
can anyone share a technique on making horizon full of buildings and trees thats looks realistic enough to make an aerial flythrough one in which it shows 4 miles in the horizon.
drawing is the physical manifestation of imagination. |
Name: Claudio Branch |
"Realistic enough" is somewhat subjective, but ultimately your approach needs to be in accordance with your project budget, your technical abilities and the expectations of your client.
Down & Dirty Grab a digital camera, go out and take a lot of pictures and tighten them up in Photoshop. Create large montage textures with alpha masks and map them onto several cylindrical planes. Use a sky dome. Middle of the Road Build a few low-poly buildings and use commands like Scatter, Particle Systems or Advanced Painter (search CGA threads) to populate the scene with a mix of 3d and 2d elements. Use a skydome and/or HDR. Top Shelf Go full 3D on the trees and buildings. Use an alpha mask on the outskirts of your terrain to blend into a hi-res HDR. The first approach is definately the "cheapest" in terms of rendering time, but still a whole lot of Photoshop work to pull off nicely. If you have been doing large exterior scenes for awhile, the other two should suffice. Good Luck.... |
| adding a background behind a window | salf | Photoshop | 4 | September 5th, 2007 10:50 AM |
| 1.5 final HAS BEEN RELEASED | tdarcy | VRay Render | 13 | August 9th, 2007 11:24 AM |
| V-Ray Version 1.5 Officially Released! | Jeff Mottle | CGA News | 1 | August 9th, 2007 05:48 AM |
| Newbie to 3dsmax needs help - 2D image | didarx79 | 3ds Max | 4 | April 12th, 2007 06:51 AM |
| Adding a Background | baker1444 | VRay Render | 5 | October 23rd, 2006 11:10 PM |
