Old June 2nd, 2008   #1 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
Default Roof Tile w/ spec how would you?
i have this Bacon Blend roof tile that i need to apply to a 3d model of a Site adapt project
problem is Redland Tile does not offer this blend as a material on their site in any good image. it is composed of several tiles from their palate.
besides the fact i am no expert at rendering roof tiles. how would you do this roof tile? where you know the specification but have little to work with?
i am thinking displacement map, does anybody have something that might help me?
attached are what i have, i made that one texture tillable but not perfect for a 2d color elevation from the larger photo.
Antisthenes is offline
Old June 2nd, 2008   #2 (permalink)
Brian Smith's Avatar
Default Re: Roof Tile w/ spec how would you?
this might help... http://3dats.com/products.asp click on the sample chapter for the intermediate/advanced book...it's on creating roofs
Brian Smith
www.3dats.com
Brian Smith is offline
Old June 2nd, 2008   #3 (permalink)
Belgium
i will not be using MAX, i know it but that would be to slow and i don't even have it.
I can model a roof all day and night my problem is solely the texture and how to make a acceptable roof tile texture bump/displacement map based on colors/materials seen in the image above, from Redland Tile's site.
value engineered and under a time constraint
do you model your tiles? i feel this would be too expensive (hi poly)
Old June 2nd, 2008   #4 (permalink)
Name: Hemant Maheshwari
I Always Do Modeling Of Tiles...I know Its To Expensive and Hi-Poly ...But I think This The Good Way To Get The Result What we want...
Thanks And Regards
Hemant
mayamax is offline
Old June 2nd, 2008   #5 (permalink)
If it is just the one house and you want that kind of detail, then you must model it, it would probably be quicker than building a custom displacement map.
If your using Maya to build a roof like the one in the picture and you have physics simulation maybe you could drop them into place... or by the looks of that roof nuke it with megaton
johnvid is offline
Old June 3rd, 2008   #6 (permalink)
Belgium
Question Re: Roof Tile w/ spec how would you?
i find this Vray displacement map but it does not match the colors of the actual product. PLUS i want over grouted any body good at displacement maps or knows a good method for faking geometry with them?
http://maxmaterials.com/vray/index.p...placement.html
http://www.pixelab.be/blog/2007/09/2...ling-geometry/
this might work best so far..
http://www.vray-materials.de/all_materials.php?mat=1691
quick way to make tile roof SgWRX 3ds Max 5 February 18th, 2008 05:27 PM
how do u create roof tile ishpalsingh VRay Render 3 May 22nd, 2007 01:36 AM
Artificial slate roof tile texture derijones General Discussions 6 June 24th, 2005 06:26 AM
Spanish Roof Tile Tutorial raterry 2D/3D Tutorials 6 May 9th, 2005 05:58 PM
Conical Tile roof Chad Warner Autodesk VIZ 2 May 13th, 2004 08:34 AM
