Old June 5th, 2008   #1 (permalink)
Default hmmm weird daylight system
just been doing testing in max 2009 and mental ray
trying to light an interior but i seem to think that when using sky portals, changing the mrsun intensity has no effect on the scene whatsoever, other than making the sky portals not as blown out, see the attached images
the only difference between the two is that one where the sky portals are really bright has the sun set at 1
the other has sun set at 0.2 with a bit of transparency on portals???
any thoughts
daveb867 is offline
Old June 5th, 2008   #2 (permalink)
Name: Novel Hernandez
Default Re: hmmm weird daylight system
I thought the sky portal transmitted sky light not sun light. Try increasing the sky intensity.
novelh is offline
Old June 5th, 2008   #3 (permalink)
sorry yes they do, but i also thought they directed the correct amount of photons through the relevant window, in which case photons come from the sun.
but if there is sunlight entering the room through windows, you would assume that decreasing the mulitplier of the sun would have an effect on the whole scene rather than just the intensity of the portals???
or have i got mixed up
daveb867 is offline
Old June 5th, 2008   #4 (permalink)
The MR sky shoots it's own photons (seperate from the sun) and just to confuse things moe the manual states:
NOTE
mr Sun and mr Physical Sky can inherit parameters from mr Sky even if the
latter is off.
The sky portals gather sky light only, not sun light. I think I read somwhere that sky portals work best when the sun isn't shining through them?
Also make sure that you delete or don't save the FG map between tests, as this will transfer the lighting info.
I hope this helps...
Macer is offline
Old June 5th, 2008   #5 (permalink)
Brian Bradley's Avatar
The Portals do indeed shoot photons but the
MR Sky itself doesn't.
Regards
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline
Old June 5th, 2008   #6 (permalink)
Justin Hunt's Avatar
The portals just get the colour from the mrsky, not intensity or anything else.
Think of them as glorified Area lights.
jhv
Justin Hunt is offline
Old June 6th, 2008   #7 (permalink)
Okay, so the MR sky doesn't shoot photons - but is it like an area light? How is it treated by the render engine? Just curious as to how it works. It shows up as a ray traced light at render time.
Macer is offline
Mental Ray/Image Based Lighting & the Daylight System? Brad_S Mental Ray 4 January 30th, 2008 04:13 PM
daylight system, radiosity and interior space ninghai 3ds Max 7 January 8th, 2007 01:32 PM
Shadow study using direct light with Daylight system issue ctasker Autodesk VIZ 5 November 30th, 2005 09:11 AM
Daylight System Washed Out ivanjay Autodesk VIZ 9 February 17th, 2005 02:23 PM
Daylight system & Interior ninghai 3ds Max 17 September 30th, 2004 04:42 PM
