Old June 9th, 2008   #1 (permalink)
upshot's Avatar
Default HDRI lighting or sky??
I'm mostly interested in doing some HDR skydomes (since I enjoy capturing them as well). I have no idea how to use them as the exclusive lighting with mental ray? Anyone know how to do this? I tried using mr Physical Sky and adding the HDR to the background map but it doesn't seem to be actually lighting the scene...
upshot is offline
Old June 9th, 2008   #2 (permalink)
Default Re: HDRI lighting or sky??
You have to put it in the SKY LIGHT..light..gizmo thingy
there is a slot where you drop it in then, drag it into MAT editor if you have to adjust the brightness through the RGB level
pthomas1172 is offline
Old June 9th, 2008   #3 (permalink)
upshot's Avatar
ah I see.. so I assume I should use my low res IBL in the 'sky light' and my high res reflection map in the environment map slot... I also assume I should be turning GI on as well?
I think I'm starting to get this... Thanks!
upshot is offline
HDRI Skies and Vray * Sky rendered greyish ludo21 VRay Render 2 October 21st, 2007 07:11 AM
Internal Lighting With Vray Sky / Sun & Physical Cam JamesTaylor VRay Render 25 September 17th, 2007 08:56 PM
Vray HDRI lighting problem the_tomohawker VRay Render 2 July 10th, 2007 08:35 AM
My first effort at Vray HDRI lighting guitarboy Work in Progress (WIP) 9 February 25th, 2007 02:35 PM
