Old June 19th, 2008   #1 (permalink)
Name: Khaled Haj Hussein
Default Difference between Mix and blend maps?
Hi, can anyone briefly explain the difference between using a mix modifier to a arch mat or a blend mat right away?
Say, I want to replicate a worn metal painted surface on a pot...I'd put a mix modifier to a chrome mat. In color one, a falloff for the tint, then in color two a rust map. Both controlled by a Perlin Marble map for instance. Would that work or would using a blend mat right off the bat?
If so, why?
Thanks!
Last edited by hendrix2430; June 19th, 2008 at 06:10 AM. Reason: edit, wrong phrasing
hendrix2430 is offline
Old June 19th, 2008   #2 (permalink)
Name: Dean Al-hilali
Wales
Default Re: Difference between Mix and blend maps?
have a try...
deanomagino is offline
Old June 19th, 2008   #3 (permalink)
Claudio Branch's Avatar
To the best of my limited knowledge...
Blend is a material type that allows you to combine other material types (Ex. Standard+Matte)
Mix is particular map that allows you to combine other types of maps (Ex. Falloff+Noise).
They behave the same way, but handle different entities (map or material).
Claudio Branch is offline
Old June 19th, 2008   #4 (permalink)
I got back home and sure enough...this thread is pointless now.
Blend is indeed for materials and mix is just more maps themselves. I could have sworn both were for maps AND materials, which is why I started the thread w/out checking first. Disregard this thread then...
