Name: Monte Caly |
Hi
i want to do a tiled texture where i have 5 variations of the same square, if i use the checker i can put 2 maps in the diffuse channel, is there a way use more maps than 2 maps in the diffuse channel ? |
Yes. You could use Tile maps with no grout (0) and high Fade Variance. Use the tile to mix between the maps and add more levels as you need.
Check the file(mat lib). This would work for four different maps. That's where the levels of mixing come to play.
Homer Simpson: Facts are meaningless. You could use facts to prove anything that's even remotely true! |
| searchable maps in material/map browser | Chad Warner | 3ds Max Wish List | 0 | December 28th, 2007 08:05 AM |
| Distributed rendering with Vray? Any clue to Maps diseapearing | jeandelessard | Hardware and Technical Discusions | 9 | October 31st, 2007 01:41 PM |
| FG/Photon Maps | louis.cho | Mental Ray | 2 | June 5th, 2007 05:01 PM |
| Panorama Missing Maps | lost in 3d world | Autodesk VIZ | 5 | November 17th, 2006 01:34 PM |
| Missing Maps on Merge | mbr | 3ds Max | 2 | October 8th, 2004 06:54 AM |
