Old June 23rd, 2008   #1 (permalink)
Default Night sky in FRY - NOT POSSIBLE?
When I was playing with FRY 1.8 DEMO I remember it was able to render very nice night skies. And it was automatic, all you had to do is set the time of the day to evening hours. And you had beautiful dark blue sky...
Yesterday I was playing with new DEMO, RC. The night sky is gone. I was trying really hard to get that "blue" night... But I couldn"t...
I'm just wondering, was I doing something wrong or that feature is really not there anymore?
P.S. I even remember seeing skies with stars...
isagreg is offline
Old June 23rd, 2008   #2 (permalink)
Fran's Avatar
Name: Frances Gainer Davey
Default Re: Night sky in FRY - NOT POSSIBLE?
Hi Isa,
The night sky feature has been removed until further notice. You can get better results with a good-quality hdri and with Importance Sampling enabled in the Environment settings.
Hope that helps.
- Fran
Fran is offline
Old June 23rd, 2008   #3 (permalink)
Thanks for reply.
Too bad, that was a really nice feature. And FRY was the only engine that could do night skies...
isagreg is offline
Old June 25th, 2008   #4 (permalink)
Name: Ryan Spaulding
What a stupid thing to do...take away a feature that seemed to be working well and was unique to the program? Any ideas why?
RyanSpaulding is offline
Old June 26th, 2008   #5 (permalink)
F J
F J's Avatar
hmmm, to compell the trial users to buy it?
(unless i misunderstood it being locked on the trial for actually removed :X)
F J is offline
Old June 30th, 2008   #6 (permalink)
It's removed both from trial and full versions.
isagreg is offline
Old July 6th, 2008   #7 (permalink)
New Zealand
is fryrender that easy to use?! just click night sky and it'll render a night scene? I've been using vray should i switch?
own1221 is offline
Old July 6th, 2008   #8 (permalink)
IceAged's Avatar
United Kingdom  Send a message via MSN to IceAged
Yes - as 'easy' as going outside and taking a photo of the night sky with a real camera. The end product however will not look very impressive unless you invest the time into understanding how the camera works under those sort of conditions.
Being a sort-of 'simulated camera', Fry will produce drab looking images if you simply 'point and shoot' - just as a high end camera in real-life will not necessarily give you stunning photos using the default settings.
IceAged is offline
Old July 6th, 2008   #9 (permalink)
New Zealand
So with FRY do you still have complicated render settings like in Vray? choosing the subdivision amounts, noise thresholds etc? and how is the light controlled, is there a selection of omnis and suns that you input?
Going outside and taking a photo of a building i modellled in max sounds really easy, and realistic - since its a photo - even if it were to look flat or dull, photoshop could be used aswell to touch it up...?
own1221 is offline
Old July 6th, 2008   #10 (permalink)
Fran's Avatar
The render settings in fryrender do not pertain to the global illumination simulation per se. They have to do with camera settings, the way you set up your lights in the scene, your materials settings, and the geometry of your scene (in other words, the essential things that make up a scene). However, there are no "GI Settings".
In Vray, the settings you mention control the quality of your GI and the user will balance that against render time and the quality of the final output they require. In fryrender and other unbiased renderers, the longer you let the image render, the higher the quality and you can stop it at any time.
Fryrender has a physical sky and sun system that you can set in any way you like. It also has simple environment lighting that will accept a color or hdri input. You create lights by applying an emitter material to geometry.
- Fran
Fran is offline
Adding realistic clouds to sky or rendering Timothy Saunders 2D/3D Tutorials 10 August 18th, 2008 07:15 PM
Vray physical sky question Tommy L VRay Render 4 January 31st, 2008 07:12 AM
Twilight / Night sky HDRI alexthg General Discussions 7 June 1st, 2007 05:21 PM
to sky or not to sky crazy homeless guy Work in Progress (WIP) 9 October 23rd, 2005 03:39 AM
CIE standard overcast sky sim Glen - UK Lightscape 9 March 29th, 2005 07:29 PM
