Name: Christian Molloy |
Who out there are using this combo for Arch Vis and getting great results...?
I have been using Rhino for almost 3 years and am very reluctant to switch to 3ds Max (even though I have a copy of 8) I just find Rhino way more user friendly. What with Vray and other programs being developed to work/plugin with Rhino and Rhino's ability to create almost any shape - with Vray as the rendering package will it look the same as a model rendered with Vray from Max...??? Im not too sure of the advantages that Rhino has over 3ds Max or visa-versa... Also I have experienced getting some of my models up to 300mb in size and was wondering how to better handle overall panning shots that need to take in alot of info - making it harder to delete parts of the model to cut down on the chances of crashing etc... Whats the largest model size - fully textured that some of you out there have experienced...??? |
Name: Jonas Callewaert |
that all depends on the job
take shortcuts and use less complex geometry where you can if you are approaching models that big i have no crashes. go ahead and upgrade the v4 for sure so you can have all the abilities of autocad in it
| Rhino and Vray - How good is it...??? | SSPEIPER | Rhinoceros | 4 | June 24th, 2008 04:45 PM |
| VRay for Rhino and Sketchup: any limitations? | emu | VRay Render | 1 | November 21st, 2007 02:07 PM |
| I need information of Vray for Rhino | autocad | VRay Render | 0 | October 10th, 2007 06:09 PM |
| Vray for Rhino 4.0 | brentwatanabe | VRay Render | 3 | October 2nd, 2007 01:35 PM |
| Rhino and Vray | manta | General Discussions | 12 | October 4th, 2006 05:01 PM |
