Old July 3rd, 2008   #1 (permalink)
jinsley's Avatar
Default Wipe out Command in AutoCAD
Working in a larger firm (50 - 60 people) I have recently been dealing with an outbreak of the wipeout command being used in our CAD drawings...
I have had nothing but trouble with its use in the past, having it cause huge amounts of drawings to come back from the print shop with massive amounts of black splotches where ever this command was utilized.
How do you guys deal with this in your offices?
I'm sure that it must have some purpose, how do you get your drawings to print correctly? They view fine in .pdf format on-screen, but once they go to print any areas blocked out by "wipeout" show up black...
As it stands Plan B is to just keep on Given'r.
jinsley is offline
Old July 3rd, 2008   #2 (permalink)
prodham's Avatar
Default Re: Wipe out Command in AutoCAD
james
wipeout in autocad dates back to pre-paperspace (or at least before viewports could be shaped)......it really has no place in current practice except maybe for layered colour illustration in autocad (which i don't do).
it does seem to pop up in some form when importing vectorworks files as well.....not sure how to deal with that at the moment.
you should be able to turn all the wipeout frames on to delete though....you've tried that ?
prodham is offline
Old July 3rd, 2008   #3 (permalink)
jinsley's Avatar
Thx Paul, that is how I have been fixing the problem so far... its just a pain in the ass to have to check for it and not something I always think of doing... oh well, something to talk about at the Friday afternoon meeting.
Is there anyway to fix the problem so that the drawings don't print with black areas?
jinsley is offline
Old July 3rd, 2008   #4 (permalink)
prodham's Avatar
are you sure the source of the wipeout objects is autocad though ?
i'm dealing with some vectorworks drawings that are full of them. i found them on one layer called 'none', but i suspect that might be just a user choice - and not a program feature.
i just use a filter on the layer and it finds them all - then delete !
prodham is offline
Old July 3rd, 2008   #5 (permalink)
jinsley's Avatar
I have seen the "none" layer before on all the drawings from a landscaper we use, they say that it has to do with the way their blocks operate in Vectorworks...
I am pretty sure though that most of the instances that I have come across were created by people in house.
I was going to ask you the other day if you knew of any Max or Mental Ray user groups that got together once in a while in Vancouver that dealt with visualization... any ideas?
jinsley is offline
Old July 3rd, 2008   #6 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
what i do is make a pen color that has 0% screening and that has the same effect(to wipe out in side bubbles or any other situation you want to slip a white paper layer between other layers to increase legibility in noisy space)
Antisthenes is online now
Anyone else model in AutoCAD? Anyone use file linking? Reitveld AutoCAD/AutoCAD Architecture 44 September 27th, 2008 05:59 PM
Learning AutoCAD...finally Aaron2004 AutoCAD/AutoCAD Architecture 1 August 19th, 2007 10:58 AM
AutoCAD 2d to 3d Max Architectural Renders Odunayo General Discussions 4 June 27th, 2006 03:54 PM
Autocad & max yosa_b Finished Work 6 August 3rd, 2005 08:02 AM
Render in AutoCad P.R.S. Sivakumar General Discussions 13 September 11th, 2003 05:33 AM
