Old July 8th, 2008   #1 (permalink)
muchhal.sandeep@gmail.com's Avatar
India  Send a message via Yahoo to muchhal.sandeep@gmail.com
Default Motherboard confusion
Hi all,
I m planning to go for a dual Q6600.
actually intel person i visited him personally is saying that thr is no intel board which supports 2 q6600. I cant understand him and i cant find anything on intel site as well .
can anyone advice me a Board in intel or Gigabyte or Asus .
I know AJlynn will be really angry by this kind of question but i need an urgent help so please
Regards:
Sandeep (got a new machine)
(Intel 5299-ws chassis, 2 X e-5420 , 500-XVN MB, 4 GB FBECC Ram ) This is what sandeep is all about
muchhal.sandeep@gmail.com is offline
Old July 8th, 2008   #2 (permalink)
kippu's Avatar
Default Re: Motherboard confusion
of course theres no board which will support dual quad 6600, of course you can get a mobo for dual quad core xeons ...which will require ecc ram which will cost quite a bit..so its not really really worth it ..
www.renderviz.com
kippu is online now
Old July 8th, 2008   #3 (permalink)
AJLynn's Avatar
Well now I'm just going to have to mock you, because as you said the question has been asked and answered. Not surprisingly, the Intel person was correct. And you can guess, I am sure, the reason you can find no information on dual socket MBs for Core 2 Quad chips.
It's because... ready for this?... can you guess what's coming?... There is no such thing as a dual Core 2 Quad system. Only CPUs that use the 771 socket, such as Xeons and some Extremes, can go dual; socket 775 CPUs, such as Core 2 Quad, Core 2 Duo and Pentium 4, can not.
AJLynn is offline
Old July 8th, 2008   #4 (permalink)
so if I am planning for a dual processor i shall move on to xeon
but as i have found that although the processor cost being the same appx for xeon 5405 (2 GHZ) and Q6600 (2.4 GHZ) the complete Machine will be on higher side due to a server board and ECC ram when i move to xeon.
is thr some way out or should i go for dual xeons.
Regards:
Old July 8th, 2008   #5 (permalink)
AJLynn's Avatar
No, you must choose - the higher cost is the tradeoff for the higher end hardware.
AJLynn is offline
Old July 8th, 2008   #6 (permalink)
I have got this config then :
2 x Xeon 5405
intel 5000 VSA motherboard
4 GB DDR II ecc
500 GB sata HDD
55000 INR (42 INR = 1 USD)
all the further details and rest all the things i will post by a day more after collection some information for the final feedback.
thanks AJLYnn and Maria
Regards:
Old July 8th, 2008   #7 (permalink)
Skulltrail and QX9770...and the QX9770 is a socket775 cpu btw! With that said, it is no way worth the price on those chips.
Slinger is offline
Old July 8th, 2008   #8 (permalink)
AJLynn's Avatar
Are you sure? If I search Newegg for a Skulltrail board I find the Intel 5400XS which has this in the specs:
Supported CPU
CPU Socket Type Dual LGA 771
CPU Type Intel Core 2 Duo Extreme in LGA771 package, Intel Xeon in LGA771 package
AJLynn is offline
Old July 8th, 2008   #9 (permalink)
kippu's Avatar
skulltrail is 771 socket , you would probably need a q9775 ,
good luck sandeep
www.renderviz.com
kippu is online now
Old July 8th, 2008   #10 (permalink)
If you go with dual processors its worth considering paying extra to get a motherboard based on the 5400 chipset (designed for the xeon 54xx series).
They can support faster ram (FB DDR2 800) and a faster FSB (1600). Not only will this provide you with better upgrade options in the future, with a speck of electrical tape and the faster memory, a E5405 should overclock from 2.00G at 1333fsb to 2.4G at 1600fsb. More power for less! You'll have to do you research first to make sure you get the right components, but its worth the effort.
Macer is offline
Dual processor desktop motherboard aligrafix Hardware and Technical Discusions 11 June 1st, 2008 07:38 AM
Dual Opterons or Core 2 QUAD??? Server motherboard tasi55 Hardware and Technical Discusions 3 October 1st, 2007 06:02 PM
lost motherboard cd 3dsmaxed Hardware and Technical Discusions 3 November 27th, 2006 07:21 AM
Which Motherboard Saturn Hardware and Technical Discusions 3 July 21st, 2006 05:23 PM
Dual Processor motherboard suggestions JamesTaylor Hardware and Technical Discusions 0 February 3rd, 2005 03:05 AM
