Hi To all,
since a few days i tried to solve a problem but i don't get the point: Software: 3dmax 2009 design Render: hosted Mental Ray I want to render a house, with mr_sun and mr_sky, i added the mr_physical_Sky shader ... in enviromental render setting. this works. But i want a picture with clouds, so í added instead of the mr_physical_Sky a bitmap with blue sky and clouds, but when i render the background is black instead of the clouds and blue sky. Do i unterstand something wrong?? Thanks for helping Uwe
Reality is not what you see, reality is what you Want to see. http://www.make3d.eu |
Name: Joel Callahan |
I think you have to crank the multiplier on the output of the cloud jpg REALLY HIGH....
Just to make sure I understand, you've used a custom map in the mrPhysical Sky, right? |
Name: Justin Hunt |
for a full and detailed expination of whats really going on read Master Zaps Blog
http://mentalraytips.blogspot.com/ look for "Why does mental ray Render (my background) Black? Undestanding the new Physical Scale settings " jhv |
Yes custom map on mrPhysical Sky.
Now it works - the high output solved it and you have to adjust in the bitmap/map output the RGB curve to control the kontrast and the gamma.
But the next effekt which appears in my mockup installation ist that the skybitmap dont mirrors in mirror surfaces . - funny ne? the material on the sphere in the attached picture is chrome, you see it reflects the basic skycolor and the ground but not the skybitmap.
Yeah, I brought in one of the sunset panoramics from the ArchMat folder and made the multiplier 20. Not as vibrant as a HDRI, but it offers some variety over the solid blue.
So works now tried different sun settings. The only thing i didn't found realy out. how you did in the scene the lensflare.
here also some pics
| Maya v. Mental Ray Shaders | hd_leach | Maya | 3 | May 9th, 2007 12:13 PM |
| Refer to the MR-section for rendering with Mental Ray - DO NOT ask in this section | nisus | 3ds Max | 0 | February 26th, 2007 05:09 AM |
| Problem with Mental Ray | drvox | 3ds Max | 5 | June 20th, 2006 05:30 PM |
| rendering using mental ray.. | prashanth | 3ds Max | 4 | September 21st, 2005 01:47 AM |
| Mental Ray Shadow Map | Ninja | 3ds Max | 2 | July 21st, 2004 09:49 AM |
