Old July 17th, 2008   #1 (permalink)
Kuwait  Send a message via MSN to murtazasimari
Default 3D max problem
hii guys
i install 3d max9 32 bit & i install properly but its showing one error
i don't know this is regarding hardware or software problem please just
give me your advice...
murtazasimari is offline
Old July 17th, 2008   #2 (permalink)
WAcky's Avatar
Default Re: 3D max problem
you need to post more information if you want help.
Is this occuring when you try a certain function or is it happening after xx minutes of max being open?
James Burrell
Pixel Constructions
WAcky is offline
Old July 17th, 2008   #3 (permalink)
its happen while rendering the image i put some furniture blocks from autocad
& i import the file to 3D max than i applied materials when i click on render than its showing error.
Old July 17th, 2008   #4 (permalink)
WAcky's Avatar
Ive never tried to import a block but i'ver heard bad things about them...
Try exploding the block before you import it. I have no idea if this will work but it might be worth a try.
James Burrell
Pixel Constructions
WAcky is offline
Old July 17th, 2008   #5 (permalink)
thanks James..
but i tried also its also not working anyway i install again the application
& try again same thing...
Old July 17th, 2008   #6 (permalink)
kippu's Avatar
how about file linking ?
www.renderviz.com
kippu is offline
Old July 17th, 2008   #7 (permalink)
i just import the file from autocad to 3d max...thats it
Old July 18th, 2008   #8 (permalink)
you are very far from the zero point.
i don't know if this has a relation whith your problem, but you should do this thing properly.
center your autocad drawing or export a wblock whith base point near your object. being too far from zero can cause many geometry problems....
you should first clean your autocad drawing, purge it, control it, center it around zero or move your ucs, AND THEN export it.
Mike. is offline
Old July 18th, 2008   #9 (permalink)
SandmanNinja's Avatar
And from an earlier post:
To centre the origin in AutoCAD (preparing to bring it into 3DS):
in autocad, use the 'move' command (M) and when asked to select objects, type 'all' (make sure all layers are on and not frozen/locked)
hit 'enter' and when asked for a base point, select a point in the center of your model (or where ever you want the origin to be).
once you have that, then type in 0,0,0 to move it - this is the origin point in autocad where the intersection of the X/Y/Z axis meet.
-SandmanNinja
website
SandmanNinja is offline
Old July 20th, 2008   #10 (permalink)
thanks dear..
but i installed 3d max 8 again coz i think my 3d max 9 is corrupted..& its working fine but some time i need to consider all above points...
thanks buddy...
3d max crashing mskin General Discussions 4 July 14th, 2008 03:43 PM
which program is usefull for modeling architecture and import to 3d max? jodapiento 3ds Max 7 June 13th, 2008 01:23 PM
DWG to 3DS Max problem christr 3ds Max 13 April 3rd, 2008 11:59 AM
Funny problem with Quad menu in Max Koper 3ds Max 2 March 15th, 2006 08:29 AM
funny problem in max about snaps 3dsmaxed 3ds Max 3 March 2nd, 2006 12:03 PM
