Old July 23rd, 2008   #1 (permalink)
Guernsey
Default Render Machine
Hi all,
I have a spare Tyan Tempest i5400XT motherboard and instead of selling it I was wondering about the options for creating a dedicated render machine.
I am working from a fairly small home office and for this reason noise and space may be an issue.
The 1U rackmount cases seem to have a large footprint and im guessing they are fairly noisy? Im also concerned about cooling a case like this, I presume they are meant to be in a rack with external cooling so I cant just put it in a cabinet.
Also wanted to know about operating systems for a server. Can i send renders from a 64 bit machine to a server that was running windows xp for example. I am probably not going to go over four gigs of RAM for the server machine so would I need a 64bit OS otherwise?
Do I need much RAM in a render machine?
Any help is very much appreciated!!
Cheers!
Gander0 is offline
Old July 23rd, 2008   #2 (permalink)
AJLynn's Avatar
Default Re: Render Machine
Why a rack? It's only one computer. Just get some EATX case. You'll need the Xeon chips for it, at least 4GB or FBDIMM memory (more is an option with 64-bit Windows) and the rest of the computer, of course. If it's just a render node and you have another computer for the workstation, it doesn't need a good video card. It does need a good power supply.
AJLynn is offline
Old July 23rd, 2008   #3 (permalink)
shaneis's Avatar
Go here http://www.tyan.com/product_board_detail.aspx?pid=562 and it'll give you all the info you need about compatible hardware and software
shaneis is offline
Old July 23rd, 2008   #4 (permalink)
Guernsey
Many thanks for your replies! AJLynn, looks like I will just get another EATX case then.
What do you think about the operating system? I am using vista ultimate on my workstation but I have a copy of XP pro (not 64bit) from a previous machine and was wondering if i could use this on the render machine without any OS compatibilty issues?(obviously won't be able to go over 4GB Ram.)
Gander0 is offline
Old July 24th, 2008   #5 (permalink)
Ky Lane's Avatar
Id keep the nodes specs same or higher than the workstation. Nothing more annoying than setting something to render overnight, to come in the next morning to see it crashed on the 3rd frame.
Ky Lane is offline
Old July 24th, 2008   #6 (permalink)
AJLynn's Avatar
You could run XP32 but you'll be annoyed if you try to farm renders between 64 and 32 bit Max versions.
AJLynn is offline
Old July 25th, 2008   #7 (permalink)
Guernsey
Ok, many thanks for your replies!
Just seemed a bit steep to have to buy another vista ultimate for a machine that isn't doing aught but rendering.
I guess im gonna have to deal with it if i take this course of action
Cheers
Gander0 is offline
Old July 25th, 2008   #8 (permalink)
AJLynn's Avatar
There's also no reason you need Ultimate for this sort of thing. Why not a 64-bit install of Business?
AJLynn is offline
Old July 25th, 2008   #9 (permalink)
SandmanNinja's Avatar
When I got my computer a few months ago, the shop knew Ihaw I hated Vista but sold me a copy of Vista CorpCorporate (or something like that) - which gives me XP64 as well as Vista so I have an 'easy' upgrade path. Might want to consider it. It was only a f ew dollars more and he absorbed the cost difference in the system price.
-SandmanNinja
website
SandmanNinja is offline
Old July 27th, 2008   #10 (permalink)
Guernsey
Great stuff, thanks for those replies.
I was thinking that ultimate was the only package with a disk for 64bit for some reason
Gander0 is offline
Maxwell Render 1.5 Maxer Maxwell Render 205 August 4th, 2007 01:59 PM
Weird Render Error?? AFK_Matrix 3ds Max 2 May 9th, 2007 04:34 AM
request to criticise the work anindia Work in Progress (WIP) 4 April 5th, 2006 02:47 AM
Cheap render machine Garry Clarke Hardware and Technical Discusions 6 December 21st, 2004 02:09 AM
Render Elements Crash lebbeus 3ds Max 0 December 5th, 2004 10:51 AM
