When using the Vray sun it automatically puts in a VRay sky environment map. My question is does this map then give me my environment lighting????
Or do i still need to turn on GI Skylight in the vray rollout??? From what i gather they are both doing the same thing, in other words i could use one or the other??? |
Name: Joseph Skowron |
By putting a Vray Sky in the environment slot of your dropdown, you are able to control both the Sky and the environment individually. You can tone down the VraySky and bump up the environment lighting in your dropdown menu or vise-versa.
Name: Trevor Tizard |
Absolutely. The vraysky was designed to be used with the vray sun and physical camera. They don't all have to be used together however.
Personally I use them all together, or none. |
i quite like using the physical cam regardless of the scene, as i like the exposure controls on it.
but with regards to lighting, i guess it depends whichever solution does what i need it to do in the quickest time and renders the fastest but i do quite like the way the sun/sky changes colours etc when you move it around in 3d space is there a direct control for setting time/date/location in vray or has that not been introduced yet?? btw thanks for the help so far guys |
| Shadow Problems with Vray Sun and SKY | THEPRAYINGMANTIS | VRay Render | 1 | June 2nd, 2008 10:01 PM |
| Internal Lighting With Vray Sky / Sun & Physical Cam | JamesTaylor | VRay Render | 25 | September 17th, 2007 09:56 PM |
| HDR,Vray Sun, Vray Sky, Vray phy: camera | mmakilm | VRay Render | 17 | May 24th, 2007 11:12 AM |
| Vray Sun and Sky settings? | antonio_frias | VRay Render | 6 | April 4th, 2007 11:27 AM |
| Vray sun and sky test | mahorela | Work in Progress (WIP) | 29 | April 2nd, 2007 12:32 AM |
