Old July 31st, 2008   #1 (permalink)
Three D's Avatar
Ireland
Default Backburner benefits?
Hi.
Having just setup Vray DR for the first time I was wondering if somebody can tell me the benefits of using Backburner against not using Backburner. The few DR's I've done so far have worked well without Backburner so do I really need to use it? Thanks for your advice.
Three D is offline
Old July 31st, 2008   #2 (permalink)
Chad Warner's Avatar
Default Re: Backburner benefits?
VRay DR and backburner are two completely seperate applications. You'd use backburner for rendering an animation, or for rendering strips on a large image (which is essentially the same thing as DR), so you don't need backburner to use DR.
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Old July 31st, 2008   #3 (permalink)
Argentina
hello, backburner an DR have different objetives. backburner is used to have an organized Render list.
In my studio we use backburner to leave the computers with the list of jobs to render, and it let us assign priority or dependencies to the jobs, so, we can prepare many renders of the different proyect that we are working on, and leave backburner assign what computer do each one, and when someone leaves your workstation at night, simply run a backburner server, and if there is some render that haven´t started, backburner assign one to them.
backburner is specially usefull too, when you are working with some scene, and you need to do a test render, but in the midtime continuing workning on the file, so yo can send it to some other computer, an continue working on the file when its rendering.
and if, for some reason, the machine that was doing some render, crash, or something happens, backburner automaticaly send it to another PC.
in other way, vray DR is used for rendering only one frame using many computers to process, but has nothing to do with organizing your render queue.
I hope it helps. make any question if you have some doubt about it.
squalo is offline
Old August 1st, 2008   #4 (permalink)
Three D's Avatar
Ireland
excellent. thanks guys. i'll give it a lash.
Three D is offline
Hopefully this may help you if you are having timeout issues with Backburner: ericbarlow21 3ds Max 4 October 28th, 2008 09:25 AM
Backburner Job Share Thox 3ds Max 0 May 23rd, 2007 03:25 AM
Big Backburner Problems Maxer 3ds Max 13 May 18th, 2007 11:06 AM
Overwrite Error Causing Backburner Files?? JamesTaylor Autodesk VIZ 2 April 25th, 2007 09:31 AM
Backburner & IP Address Brolloks Autodesk VIZ 2 October 18th, 2006 07:29 AM
