Old August 1st, 2008   #1 (permalink)
Saudi Arabia
Exclamation SpeedTree 4 and Vray DR ???
Hello eveyone
i have this problem which is on rendering the maps.
i created trees on speedtree then imported them into 3ds max 9
i use DR with 3 machines everyone of them has INTEL quad CORE 2.66ghz.
the problem is when i render the scene the maps seem like they are turned off ,except the main computer im using is not and the maps appears only on its buckets while the other computers buckets dont show the maps as i said above .
other thing is i put all the maps in the maps folder in 3ds max root folder.
unfortunatlly they didn't appear i tried to convert the trees maps from TGA format to JPEG to see if they'll work
but didn't work
if anyone had the same problem i really need to know and i'll be real grateful for the help
note:any idea how to create shared folder that i can put all the map's folder in it and all the machines on my network can access without losing the time and switching to every computer using the Remote Desktop Connection and copy the files manually
appreciate the help!!!
thank you
karol is offline
Old August 1st, 2008   #2 (permalink)
Saudi Arabia
Default Re: SpeedTree 4 and Vray DR ???
PROBLEM SOLVED THANK YOU ANYWAY
it was because i didnt install the pluin in the other machines
thank you
karol is offline
First Vray render/ problem djohnson129 VRay Render 4 June 2nd, 2008 09:45 PM
vray 2sided material nelpiper VRay Render 2 May 7th, 2008 04:10 AM
Osmosis scene with vray 1.5 bayvan VRay Render 5 August 22nd, 2006 05:44 PM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
Has anyone tried Speedtree with VRay? how it's looking? Any good? Richard McCarthy General Discussions 7 June 12th, 2004 07:41 PM
