Old August 3rd, 2008   #1 (permalink)
harrowboy's Avatar
New Zealand  Send a message via MSN to harrowboy
Question Mirror-like glass at certain angles (interior)
Hi, I've been playing with this mat but couldn't get it right.
As you could probably see in the attached img, some of the glass panels along the handrails are acting as if they were mirrors. (but the same material worked fine for the roof and shopfront windows and they are transparent)
It is just a standard glass material that I'm having..
Diffuse: black, fresnel reflections checked
Reflect: gray almost white
Refraction: white, affect shadow/alpha checked
can anyone tell what's wrong? Thx.
harrowboy is offline
Old August 4th, 2008   #2 (permalink)
Pakistan
Default Re: Mirror-like glass at certain angles (interior)
set the reflections low . a black/dark grey color.or use fall off map on reflection.with color of black and grey.
yepee9 is offline
Old August 4th, 2008   #3 (permalink)
BrianKitts's Avatar
does all of your glass have a thickness? if the roof and shop windows have a proper thickness but the railing is just a single plane, then the single plane geometry will act as a mirror.
A proper glass material needs the thickness to properly refract the light, if you only get a single refraction then you won't see any transparency in your object and you are left with just the reflection hence the mirror effect.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old August 4th, 2008   #4 (permalink)
harrowboy's Avatar
yes Brian, it was the problem with my modelling, the glass became transparent after I face extruded the geometry and applied shell. thanks.
Old August 4th, 2008   #5 (permalink)
Ky Lane's Avatar
Are they set to fresnel?
Ky Lane is offline
BG is not seen from interior through glass windows Hatem Sayed Mental Ray 2 March 3rd, 2008 12:38 AM
Mental Ray - Interior Glass richmace 3ds Max 4 July 31st, 2007 01:51 PM
Vray Interior wine glass problem claytonjamesblack VRay Render 9 June 19th, 2007 01:29 AM
glass building - interior mskin Work in Progress (WIP) 4 June 4th, 2007 07:12 AM
Kitchen Interior - Camera angles and "Nurnies" rockrat Work in Progress (WIP) 1 August 7th, 2006 08:53 AM
