Name: naveen kumar |
hi
I'm working on an interior project. The modeling, lighting and material is done in max 8 using vray 1.5RC2. A sample render of this file took around 4 mins. Just to test, i opened the same file in max2008 V-ray 1.5 (i.e. modeling, lighting and material is done in max 8), without making any changes, a sample render took around 1 hr I'm attaching scene images, light, material and rendering settings... Please help me know what the problem is.... thank u. |
Name: Scott Schroeder |
When you open an older vray scene in the latest build of Vray, a warning dialog should open stating that the settings have changed from the older builds of Vray. I think some of the changes are with the DMC settings which would defiantly lead to the longer render times.
If this dialog appears, it will ask you if you want to update the settings. I would highly suggest doing so.
Scott S. |
| Distributed rendering issue, Max 2008 | mcbatman | Mental Ray | 7 | February 21st, 2008 05:31 AM |
| glass material: comparing Max vs VRay | smr_VIZ | VRay Render | 0 | November 26th, 2007 09:12 AM |
| Difference between Max and Maya | whale | General Discussions | 16 | July 20th, 2007 02:08 PM |
| Max Crashes with Vray Render above 2000 pixels | bripatfan | VRay Render | 6 | October 5th, 2006 12:16 PM |
