Old August 5th, 2008   #1 (permalink)
Post How to use vray override material
can anyone tell how to use vray override material !! a good example for that.
rakeshtagotra is offline
Old August 5th, 2008   #2 (permalink)
kippu's Avatar
Default Re: How to use vray override material
well you apply your Vray light material as the base material .... the override material is the material which will affect your GI settings and the reflection override material will affect the materials' reflected property ...pretty simple actualy
www.renderviz.com
kippu is offline
Old August 5th, 2008   #3 (permalink)
Thumbs down Re: How to use vray override material
Thanks kippu. But i don't want to know theoretically. i need a practical example. actually i am also aware of what you have told me.
Old August 5th, 2008   #4 (permalink)
Ireland
I presume you mean..
Goto Vra::Global switches
override material
activate ie tick it.
and drop in any material you want from your material pallet.
the vray edge texture works very well, it works oike a bit map not a full material.
i make that mestake all the time.
phil
philip kelly is offline
Old August 5th, 2008   #5 (permalink)
kippu's Avatar
no phillip i think he meant the vrayoverride mtl in the material library one
http://www.spot3d.com/vray/help/150S...verridemtl.htm
www.renderviz.com
kippu is offline
Old August 5th, 2008   #6 (permalink)
Ireland
ok
Any idea when the vray release is out ?
phil
Vray Proxy with Material SunGlare VRay Render 14 May 13th, 2008 09:22 AM
vray material b, d, and reflectivity own1221 VRay Render 0 February 16th, 2008 01:49 PM
Vray polycarbonate material jorisAR General Discussions 2 December 11th, 2007 03:15 PM
Transluscent Vray Light Material How? kwerch VRay Render 3 April 19th, 2007 01:58 AM
Using merged model's Vray materials in your current Material Editor estyl VRay Render 2 January 16th, 2007 08:04 PM
