Old August 11th, 2008   #1 (permalink)
Lebanon
Default Lwf and textures
Hello guys
i set up my 3dmax so that textures i import are imported as being allready gamma corrected (almost all of them are evermotion or total textures)and everything is fine except when i pick a color from the net it turnes out much lighter than i expect so what am i supposed to do ?
i want to have the same color, not darker or lighter.
also i was wondering if u guys copy ur textures to the folder of whatever file ur working on ? cause i have to as vray doesn't seem to be able to locate them alone (wich is weird )
does the resource collector work with vray ?
any hel is appreciated, thank u very much
fadi3d is offline
Old August 11th, 2008   #2 (permalink)
BrianKitts's Avatar
Default Re: Lwf and textures
to sample colors off the web using LWF you need to apply a 2.2 gamma correction to the sample. If you take an RGB value right off your screen and type that into max you are skipping over max's ability to apply the gamma correction.
Checkout the "Color Correct" plugin on the following website
http://www.cuneytozdas.com/software/3dsmax/
once installed you can place a "color correct" map in your diffuse channel and from within that maps options select your color and apply your gamma adjustment to get an exact match.
For instance, if I sample the green in the CGA logo I get an RGB value of 112,156,0. If you key that into max it comes out too bright as your have noticed. But if you key in your gamma correction the resulting sample is a perfect match.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is online now
Old August 12th, 2008   #3 (permalink)
Thats a useful plugin - cheers.
LukeC is offline
Old August 12th, 2008   #4 (permalink)
Parker1's Avatar
Silly question...when using the CC plug-in do you have it installed on every render node? We have a 200+ machine farm and need to know if I need to write a script to install it on every node. Let me know. Thanks
Brian M. Parker
Cooper Carry & Associates
www.coopercarry.com
Parker1 is offline
Old August 13th, 2008   #5 (permalink)
Lebanon
Dear Brianthank u for ur help, actually i downloaded that plugin a while ago but i never used it as i didn't work in LWF but now is the time i guess
one more question though when u create textures from scratch in photoshop what am i supposed to do ?
than u for ur time and god bless u
fadi3d is offline
Old August 13th, 2008   #6 (permalink)
Tommy L's Avatar
Yes it must be installed on every node.
Tommy L is online now
Old August 13th, 2008   #7 (permalink)
Name: Ryan Spaulding
So THAT was the issue?!? I couldn't figure it out for the life of me so I always created a little 100x100 image with the color mapped to it and used that...
This will be much easier. Thanks!
RyanSpaulding is offline
Old August 13th, 2008   #8 (permalink)
BrianKitts's Avatar
you don't have to do anything (anymore) in photoshop, let max do it for you by setting the input gamma for bitmaps to 2.2 in your the max preferences for gamma. This will globally apply the correction to all the maps you use for textures.
Note: If you don't want to use the global correction you have that option when you select your texture as to if you want to override the max value.
Brian Kitts
ANSHEN + ALLEN
Old August 13th, 2008   #9 (permalink)
BrianKitts's Avatar
since a couple of you are picking this up, I'll make another suggestion, a great plugin for sampling colors off your screen is the "Cool Picker" found here....
http://www.idigitalhouse.com/Tech/dh_tech.html
(the max 9 version works in 2009 as well)
you can drag select from the color selector and grab the RGB values off of any window visible on your screen. Makes it really easy to sample colors straight into max. Once you've placed the .dlu file in your plugins folder for max, boot max and in your general preferences change the color selector from the default.
BTW I need to give credit for this whole process to Travis (CrazyHomelessGuy) who came up with this a couple years back.
-bk
Brian Kitts
ANSHEN + ALLEN
Old August 13th, 2008   #10 (permalink)
Lebanon
Brian this is so cool but drag selecting isn't working for me (max 2008 )
in fact dragging does'nt do anything
sorry for being a trouble
thanks
fadi3d is offline
Arroway textures in vraymtl sesim VRay Render 34 January 28th, 2008 07:45 AM
LWF (linear work flow).. shikodesign2000 VRay Render 14 January 15th, 2008 10:55 AM
LWF guidance needed. Tommy L VRay Render 21 August 20th, 2007 09:18 AM
LWF contrast Questions Advisor VRay Render 2 June 27th, 2007 11:10 AM
Evermotion has a gazzilion vray textures... Sawyer VRay Render 16 December 8th, 2006 05:38 PM
