Name: philip kelly |
I have photos taken with a 24 mm shift lense.
This has been discussed, but i don't think with a Vray Cam. I have matched the best I can, the sensor is a full one ie Canon mark II. So does anybody know how to get an accurate result with a Vray Camera. Thank you Phil |
Name: Tom Livings |
Do you know the film gate of the camera? Thats the physical width of the sensor.
#3 (permalink) | |
A camera correction modifier will allow you to mimic the shift lens characteristics or if you are using a vray physical camera the vertical shift feature will do the job. |
#5 (permalink) | |
Thank you so much...
In life, the only thing permanent is change |
and the max help document also explains it very good. just search for the 'Camera Match Utility' in the help document, not the max tutorials document.
the this is the evermation one http://www.evermotion.org/tutorials/compositing/arch/ |
| Camera match - Exterior views | ovzoc | Finished Work | 3 | July 27th, 2008 04:45 PM |
| my first camera match | Kristian | Finished Work | 6 | October 26th, 2004 12:09 PM |
| Vray and Camera Correction Modifier. It's a No-No. | crazy homeless guy | VRay Render | 2 | June 2nd, 2004 11:38 AM |
| Camera match | blaz | 3ds Max | 1 | March 21st, 2004 09:32 PM |
| camera match problems... | skogskalle | General Discussions | 0 | December 29th, 2003 12:14 AM |
