Name: Philip Bradbury |
I have playing with the camera setting and its now got really bad shadowing/ blotching. How can i correct this? Is it a texture error or a vray settings error?
Thanks phil shadow.JPG |
HI, yea i think i have seen it the red floor one? How can i tell which material is causing the "bleeding". Is it the material which the bleeding appears on or will it always be a material causing the bleed from bouncing light appearing on that one?
thanks again |
Name: Eric Sosa |
bigger surfaces bleed more than smaller, you foor bleeds a lot, dunno what color u'r walls are , cos so much bleeding
the black parts bleed too as u can see in the walls where the black is close, etc. again, whenever u fix the bleeding, u'll be able to see other problems. http://www.cg-files.com/VrayColorbleeding.html here u are m8, gl |
Nice one i will sort the floor out then rerender and submit it.
What about the gamma setting would changing these help? the walls r ment to be a grayish white lol The sofa is ment 2 be leather and i folded a tutorial to do that, do you think that is look so bad due to the colour bleed? it looks more plastic 2 me than leather Last edited by monkeyman905; August 14th, 2008 at 09:52 AM. |
| VRay and RPC Shadow Light | Ruiner | VRay Render | 2 | October 31st, 2008 08:07 AM |
| Hopefully this may help you if you are having timeout issues with Backburner: | ericbarlow21 | 3ds Max | 4 | October 28th, 2008 09:25 AM |
| vray sun with matte shadow material | fareen | VRay Render | 5 | April 9th, 2007 03:32 AM |
| Mental Ray Shadow Map issues | Quique | 3ds Max | 6 | August 17th, 2006 10:24 PM |
| Shadow issues | LukeC | Autodesk VIZ | 2 | November 18th, 2004 09:55 AM |
