hi to all friend,
"How can i stop color bleeding" i have problem with this tutorial, ( by Martijn Dekker) http://www.cg-files.com/VrayColorbleeding.html in this tutorial, three techniques describes about color bleeding but i am unable to understand Method 1. to stop color bleeding between red floor and white walls,he used saturation setting but when i did it on my pc, it is not working working.when i change saturation value in GI,there is no effect on output.all setting is default on my pc. please help me. thanks. [IMG]file:///C:/DOCUME%7E1/VIJAYP%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG] |
look at the http://www.spot3d.com/vray/help/150S...verridemtl.htm vray Override material. you can supply it with the material to use at rendertime (the normal red one) and a lower saturation material to use when calculating GI.
also you get better color bouncing when using some of the linear workflow stuff, but thats much too complex to explain, so i find it better to just suggest the override
Dave. TD / EwingCole DMG |
| Tags |
| color bleeding, vray |
