Old August 19th, 2008   #1 (permalink)
puttyface's Avatar
Default Photometrics in Vray
Hi,
I'm using Erco photometrics with Vray. I seem to have to increase the Intensity Multiplier for each light to 100000% in order to just see them. That can't be right surely can it?
This is for an exterior shot looking into a triple height foyer that i'm struggling with. One of the main reasons for the image is to demonstrate the lighting scheme from a lighting designer i'm working with, as well as to show off the spaces for publicity and fundraising.
I'm using a Vray physical camera btw.
T
puttyface is offline
Old August 19th, 2008   #2 (permalink)
Default Re: Photometrics in Vray
Post some settings, sepcifically camera settings and render settings
daveb867 is offline
Old August 19th, 2008   #3 (permalink)
Seems all the different light systems really don't work together. I found you basically have to turn the sun way down to just see any photometrics and/or standard light.
try camera for exterior = f-number 4, sutter speed 100, film speed 100
camera for interior = f-number 4, sutter speed 100, film speed 400
sun way down to 0.1
sky way down to 0.08
first bounce at 3, second bounce at 1 or 0.85
Originally Posted by puttyface View Post
Hi,
T
pyang is offline
Old August 19th, 2008   #4 (permalink)
nicnic's Avatar
image or your render?
are you trying to make your photometrics 'unnaturally' compete with the sun by any chance? sun and sky work most logically when set at 1, and expose with camera - not other way around.
otherwise switch to normal spots.
nicnic is offline
Old August 19th, 2008   #5 (permalink)
nice to see someone else on the same thinking path as me, hence why i asked for camera settings
daveb867 is offline
Old August 20th, 2008   #6 (permalink)
Maxer's Avatar
I've experienced the same issues when doing an exterior day/dusk scene and wanting to see illumination inside of a building. Cranking up the multiplier is the only way to get those lights to show up. I think it's because compared to the sun/physical sky the lights are just very underpowered and since your using a physical camera set for a daylight exposure it's very difficult to make them show up.
“There is no spoon”
Maxer is offline
Old August 20th, 2008   #7 (permalink)
Lebanon
hello guys
what nic said should put u on the right track.but i have to admit that when setting Sun and sky to 1 and exposing with your Cam u still have to struggle with your Vray or Ies multiplier.sometimes a Vray light with a mult of 1 will be burned when u up the exposer and sometimes with a mult of 6 it won't be bright enough.i guess it's got to do with the color of the light and other materials.correct me if i'm wrong and pls shed some light if u can.
thanks
fadi3d is offline
Vray material problems in vray free ssstrutz VRay Render 6 September 14th, 2006 01:06 PM
Definitive Guide to VRay and Render Passes fire3d VRay Render 21 September 6th, 2006 05:47 PM
Problems with settings for external Vray scene alfienoakes VRay Render 6 October 6th, 2005 07:58 AM
Vray, Maxwell...................?? bully712 VRay Render 16 April 5th, 2005 08:36 AM
VRay against Vray and ... Sergio VRay Render 15 May 30th, 2003 09:09 AM
