Old August 23rd, 2008   #1 (permalink)
shikodesign2000's Avatar
Default cladding material..
Hi,
I have a building with cladding material in a large portion of it.
When I put the sun object, the highlight is locating only on the top portion of the cladding object part, and the rest is natural grey undesirable looking.
How can make many highlights on this object, especially it is a box object, not organic?
Best Regards,
Sherif Massoud
www.3dshore.com
shikodesign2000 is offline
Old August 23rd, 2008   #2 (permalink)
shaneis's Avatar
Default Re: cladding material..
Could you post an example?
shaneis is offline
Old August 23rd, 2008   #3 (permalink)
without knowing much about said cladding material, I'd gather that you need a bump or displacement map to go with it in order to generate multiple highlights.
e[dub] is offline
Old August 23rd, 2008   #4 (permalink)
Claudio Branch's Avatar
Add more light sources...
Claudio Branch is offline
Old August 24th, 2008   #5 (permalink)
The cladding material is used mainly in high rise towers, like in Dubai buildings, it's simply grey metal material, I'll post an example very soon.
Best Regards,
Sherif Massoud
www.3dshore.com
Old August 24th, 2008   #6 (permalink)
amer abidi's Avatar
have you tried adding a messmooth modifier with iterations=0? assuming youve got the cladding panels modelled individually ofcourse.
could be of more help given an example.
"Well I figure it has to be bigger than smaller. Whats the point of designing a concept the size of a hot dog stand? "
J.G.
amer abidi is offline
Old August 24th, 2008   #7 (permalink)
kippu's Avatar
i am sure you mean alucobond cladding ... i am pretty sure the highlight happens around the corner where you have the sun and not uniformly in real life too ...
www.renderviz.com
kippu is offline
Old August 24th, 2008   #8 (permalink)
kippu's Avatar
www.renderviz.com
kippu is offline
Old August 24th, 2008   #9 (permalink)
nicnic's Avatar
you could chuck in some lights with 'affect specular' only (omnis, spots, vray lights anything)
make sure your material is reflective / glossy enough as well
paint a quick bump or displacement map as well based on some photos to get it to catch light.
or hand paint highlights in PS
nicnic is offline
Merging - use scene material Tim Nelson 3ds Max 4 August 11th, 2008 03:30 PM
shell material v-cube 3ds Max 1 May 19th, 2006 09:31 PM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
