Old August 25th, 2008   #1 (permalink)
Default Animation whith moving objects
Hi,
that is the first time i have to make an animation whith moving objects.
To avoid flickering on fly through animations, i used to use the method consisting of calculating and saving light cahche then irradiance map for the whole animation, and then render it from the calculated LC and IR.
Now i have no idea about how to avoid flickering in real animations, i mean whith moving objects.
Would anyone have a link, or could explain me the main ideas behind this ?
Thank you very much.
Mike. is offline
Old August 25th, 2008   #2 (permalink)
Default Re: Animation whith moving objects
http://www.spot3d.com/vray/help/150R...rials_anim.htm
This will help a lot.
Joseph Petrino is offline
Old August 25th, 2008   #3 (permalink)
kippu's Avatar
i tried that tutorial so many times and i always keep stumbling and end up using irrmap + brute force for every frame and then composite the moving object in the scene...works good for me
www.renderviz.com
kippu is offline
Old August 25th, 2008   #4 (permalink)
Thanks Guys
I'll look through each of the methods you mentionned to see what fits the most whith my needs.
i also posted on another forum and received this answer.
One way to do it would be to use the "Animation (prepass)" and "Animation (rendering)" modes of the irradiance map; there is some more info on this in the V-Ray help index here:
http://www.spot3d.com/vray/help/150...edimap.htm#mode
Best regards,
Vlado
Mike. is offline
Animation w/ moving camera and objects? gdpasteur VRay Render 3 July 18th, 2008 09:42 AM
Moving groups of objects to different layer. crazy homeless guy 3ds Max 5 March 13th, 2008 03:55 AM
How to do veryfast moving pp in the 3D animation! dinhtuan General Discussions 5 October 10th, 2007 04:58 AM
moving objects in vray animation.. shikodesign2000 VRay Render 3 April 23rd, 2007 09:01 AM
Help: Moving cars+people in an Animation visions VRay Render 0 February 13th, 2006 09:54 PM
