Old August 26th, 2008   #1 (permalink)
Three D's Avatar
Ireland
Default vray render styles for large scale model
hi. i'm not really sure what to title this thread.
i'm doing a large urban design layout (mixed use residential, commercial, retail, science and tech) for a site c.400acres and the only aspect of the layout that has been designed in any kind of way is the road layout. i'm using generic blocks everywhere and basic trees, cars, people etc. and the level of detail is low. it started out as a massing model excercise and has taken a life of its own since. the client wants images and a flythrough of the model. the result does not need to be photo-realistic so i've messed around with vraytoon and f-Edge here and there to add a bit of detail and make some low detail buildings look a bit more detailed. no textures just basic simple colours used (green for grass (obviously) white buildings, grey road, black vraytoon outlines). i've also messed around with a fake balsa model look which looked good at the start.
i'm looking for advice, suggestions and inspiration on a style or look i could apply to my model using vray and 3ds max. i'm getting very frustrated trying to make the model look half descent with very little to work with (nothing new in this place!!). unfortunately i cannot post images of my model as it's very hush hush at present. i'd be very grateful for any suggestion or help. thanks again.
Three D is offline
Old August 26th, 2008   #2 (permalink)
Name: Giovanni Rodríguez
Mexico
Default Re: vray render styles for large scale model
if its a large terrain, you can use vray proxys to add more detail to your models and keep handle viewports and saving rendertime.
i don't know how you're using vraytoon. i would need to see an image in order to give you a better advice.
3dfunker at www.3dfunka.com my personal portfolio
disidente is offline
Old August 27th, 2008   #3 (permalink)
Three D's Avatar
Ireland
thanks giovanni. i'm aware of the proxy possibilities but none of the buildings have been designed and are likely not to be designed before my deadline. i've attached some images of where i'm at. i'm just looking for some inspiration on how i could bring this low detail model to life.
Three D is offline
Vray Render - Major Problem ! navdeep2502 VRay Render 3 July 11th, 2008 03:21 PM
VRay Image - 47 Hours to Render? H-E-L-P Lester_Masterson VRay Render 8 July 8th, 2008 07:08 AM
First Vray render/ problem djohnson129 VRay Render 4 June 2nd, 2008 09:45 PM
Vray animation render problem field3d VRay Render 4 January 16th, 2007 12:34 AM
vray render Boizell VRay Render 5 November 18th, 2005 04:37 PM
