Name: chow choppe |
HI
i am trying to render an image with vray I am using a bump map for showing vinyl siding on the walls The siding is coming okay in the walls at the front but the bump is not visible at all on the side elevations which are visible in the perspective. i tried reducing the blur value of the texture also but that didnt help Please see the image and help me out ![]() why is it not visible which is not facing the sun and also in perspective Thanks |
Name: Matt McDonald |
A bump map doesn't actually do anything to the geometry of the walls so as your view becomes parallel with the surface, the bump map becomes invisible. You could use displacement, model the seams with geometry or create a diffuse map that has some of the information.
| Good Morning Everyone | STU_P | Off Topic | 40 | May 10th, 2007 06:26 AM |
| 3dsMax: independent diffuse and bump | Lupaz | 3ds Max | 11 | July 7th, 2005 08:25 AM |
| Side Elevation Renders | JHalton | General Discussions | 4 | August 24th, 2004 03:15 PM |
| some friday merff and hilarity | STRAT | Off Topic | 6 | July 9th, 2004 02:33 PM |
| Bump Map issues with G.I. | Erik Lund | 3ds Max | 3 | April 15th, 2003 10:29 AM |
