Old September 2nd, 2008   #1 (permalink)
Estonia
Default sequence through Vray Frame Buffer
Hi, I may seem like a fool, but...
Can I render a camera walk through animation in the Vray Frame Buffer? I ask because when rendering still images and useing the exposure and color curves correction utility for a better image quality, so I would like to achieve same results in animations.
Thanks to all
chortik is offline
Old September 2nd, 2008   #2 (permalink)
BrianKitts's Avatar
Default Re: sequence through Vray Frame Buffer
yes you can, but it would be better to apply those adjustments in post using your animation editor, rather than burning the correction into the animation.
Most video editors (Premiere, Aftereffects, etc) have adjustments for exposure and a curves editor.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old September 2nd, 2008   #3 (permalink)
Estonia
Hi,
If you do not mind, please enlighten me and give me a hint about how I could render my sequence through VFB although its not very common
C.
chortik is offline
Old September 2nd, 2008   #4 (permalink)
BrianKitts's Avatar
Originally Posted by chortik View Post
Hi,
C.
read the manual on enabling the frame buffer and you've got it. as long as your frame buffer corrections are applied when you send the animation to render through backburner, it will apply those corrections to the final render.
what makes you think its not common??..... I render everything through the Vray frame buffer.
Brian Kitts
ANSHEN + ALLEN
Old September 2nd, 2008   #5 (permalink)
Estonia
Hi,
My goal here is to make a small animation like 10 frames with one camera and simple light settings. In every frame I can adjust my camera position and after that I render whole sequence so that every frame will be saved separately to jpg and they have the same gamma curves etc. to each frame. I read all the manuals I could, but I did not find anything about sequence rendering. If you can send me a link or something I would appreciate it really!!!
Regards,
C.
chortik is offline
First Vray render/ problem djohnson129 VRay Render 4 June 2nd, 2008 09:45 PM
Mental Ray and Vray Proxies Usability Compared crazy homeless guy Mental Ray 10 April 24th, 2008 05:29 PM
Duplicate to Max frame buffer Maxer VRay Render 3 July 19th, 2007 11:30 AM
HDR,Vray Sun, Vray Sky, Vray phy: camera mmakilm VRay Render 17 May 24th, 2007 11:12 AM
frame buffer bradpski VRay Render 1 December 4th, 2006 10:46 PM
