Old September 2nd, 2008   #1 (permalink)
jinsley's Avatar
Default Help with specs for new machine...
I have been asked to spec out a new machine to help with the rendering and modelling I am doing for our office. It is getting more popular now and production time is becoming an issue. I have a few questions:
1.) I have suggested going with a 64-bit system to increase memory capacity and the RAM footprint. They won't allow me direct access to the network so distributed rendering seems to be out the door... are there any other options?
2.) Will a machine running 64-bit cause problems in an office which runs primarily 32-bit?
Here is the machine I am looking at,
Dell Precision T7400
Quad Core Intel® Xeon® Processor E5430 2.66GHz,2X6M L2,1333
Genuine Windows Vista® Business,SP1, with media,64,English
3 YEAR BASIC LIMITED WARRANTY
8GB, DDR2 SDRAM FBD Memory, 667MHz, ECC (8 DIMMS)
No Monitor Option
512MB PCIe x16 nVidia Quadro FX1700, Dual Monitor DVI Cable
48X/32X CD-RW/DVD Combo Drive with Cyberlink Power DVD™
Sound Blaster® X-Fi™ XtremeMusic (D), w/Dolby® Digital 5.1,
C2 All SATA drives, Non-RAID, 2 drive total configuration
160GB SATA 3.0Gb/s,7200 RPM Hard Drive with 8MB DataBurst Cache™
80GB SATA 3.0Gb/s,7200 RPM Hard Drive with 8MB DataBurst Cache™
Thanks all for your time and comments.
-JI
As it stands Plan B is to just keep on Given'r.
jinsley is offline
Old September 2nd, 2008   #2 (permalink)
StanZ's Avatar
Name: Stan Zaslavsky
Default Re: Help with specs for new machine...
hi james
i'm using a 64-bit machine and using net-render to render with other 32-bit machine and i just have to send it through to render with 32-bits.
having 8G of memory sure helps with rendering
my only comment about the above config - why such small HDrives? you might need more space if you are only using this machine for modeling and rendering.
hope it helps,
Stan
www.eagleproperty.com.au
StanZ is offline
Old September 2nd, 2008   #3 (permalink)
jinsley's Avatar
The hard drives are smaller because the office works over a server and I was told that I wouldn't need anyhting larger... does having a huge hard drive make a significant improvement to performance???
jinsley is offline
Old September 2nd, 2008   #4 (permalink)
Tommy L's Avatar
Nope. Doesnt help or hinder. a 10,000rpm drive would be marginally quicker.
Tommy L is online now
Old September 2nd, 2008   #5 (permalink)
StanZ's Avatar
as long as you've got plenty of space to save your stuff to - then u dont need it on the actual machine.
Stan
StanZ is offline
Render Machine Gander0 Hardware and Technical Discusions 10 October 2nd, 2008 09:08 PM
Trying to build rendering machine. jjsalang Hardware and Technical Discusions 1 July 2nd, 2008 02:24 PM
Need advice for building or buying a machine for rendering danb4026 VRay Render 14 April 8th, 2008 10:36 AM
Render machine PGD Hardware and Technical Discusions 48 September 11th, 2007 02:15 AM
Specs for a new machine architectandy Hardware and Technical Discusions 7 March 9th, 2007 01:26 PM
