Name: Mark Cronin |
Is anyone that has a new-ish card (DirectX 10+) using the DirectX 10 driver in Max?
If you select DirectX (instead of Open GL) it usually defaults to the DirectX 9 driver (its under Preferences> Viewports> Display Drivers). I was wondering if anyone had tried running Max using directX 10,? If so, how does it compare to DirectX 9? Does everything display correctly on your screen? do you get the same display rate or fps? I have a GTX9800 on one pc but with the DirectX 10 driver some things (mainly the view cube thingys and some menu buttons) don't display the same as they do with the DirectX 9 driver. Just curious more than anything..... |
Used it once, never used it again. Design 2009 keeps crashing. Or maybe it was my card. xfx-8800GT. Im sticking to dx9 for now
MD8 Design Solutions X3MFX Interactive Design Agency DE MAX Design PTE LTD |
Name: Jonas Callewaert |
so it seems like only gamers see the advantage at this point? i have openGL accelerated cards so i stick with openGL and dx9 for other stuff that does not have quadro/firegl support.
| Max 2009 compatibility | Timothy Saunders | 3ds Max | 5 | August 26th, 2008 08:53 AM |
| max crashing and long load time | mike c | Hardware and Technical Discusions | 3 | May 18th, 2007 09:08 AM |
| AutoCAD 2d to 3d Max Architectural Renders | Odunayo | General Discussions | 4 | June 27th, 2006 03:54 PM |
| Calling all 3ds max 6 users | Jeff Mottle | General Discussions | 1 | January 21st, 2004 04:52 AM |
| display driver in Max 6 | Brian Cassil | 3ds Max | 5 | November 10th, 2003 06:24 AM |
