Old September 27th, 2008   #1 (permalink)
Bulgaria
Default PC for rendering only
I'm thinking of buying some PCs for network rendering. The quesiton is do I need more than 4 gigabytes of RAM? They're gonna be used only as a render farm.
www.svetlinadesign.com
Architectural visualization
A.Mitov is offline
Old September 27th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: PC for rendering only
to use more than 4 gigs of ram would require a 64-bit OS.
I think RAM is pretty affordable now-a-days, and having 8 gigs can make rendering easier and perhaps quicker (big scenes).
-SandmanNinja
website
SandmanNinja is offline
Old September 27th, 2008   #3 (permalink)
toxic_box's Avatar
Iraq  Send a message via MSN to toxic_box Send a message via Yahoo to toxic_box
I'm Using a RenderBoxx it has a 16 gigz of ram for each node......In many Heavy Scenes I've Used about 12 GB of Ram at Rendering time (Especially in cityscapes).
So I Recommend 16 GB of Ram coz 8 some time not enough
toxic_box is offline
Old September 27th, 2008   #4 (permalink)
AJLynn's Avatar
That's crazy! Unless your work is really detailed, if you're overrunning 8GB you've got a problem.
AJLynn is offline
Old September 27th, 2008   #5 (permalink)
The only time I've 'run out' of the 8-gigs of RAM is when I had a lighting problem and Max got confused. User error.
-SandmanNinja
website
Old September 27th, 2008   #6 (permalink)
Lhanh29's Avatar
Viet Nam  Send a message via Yahoo to Lhanh29 Send a message via Skype™ to Lhanh29
i think 8Gb it could be Ok. i have been work with big project with a lot of trees proxies with too much detail.Some time it is "run out". I have never used 12, 16gb .. but i agree Toxic.box.
a2 Visualization.
www.a2viz.com.vn
3d modelling, 3D rendering, 3d animation.
Lhanh29 is offline
Old September 27th, 2008   #7 (permalink)
toxic_box's Avatar
Once you have a Dynamics (Particles and Fluids) Smoke Dust ....etc....16 GB is ok...
But For Archviz...I Think 8 is Fine.
Old September 27th, 2008   #8 (permalink)
FlyinHawaiian's Avatar
I've very rarely topped out my box (8gbs) though, with particles, and a lot of trees, I could see this happening. I'm really curious though, to see what sort of scenes you've worked on that have topped 12gbs. Are you able to post any images/frame grabs?
joel burbage
strivestudios
www.strive3d.com | www.joelburbage.com
FlyinHawaiian is offline
Old September 27th, 2008   #9 (permalink)
toxic_box's Avatar
Hello Joel...
My Scene is a Room with 12 characters (Children) With Cloth and hair (I Work in an Animation company - and our project is a Film not an Archviz ) and there is no Render proxies coz we work on maya 2008 / Mentalray.
I Hope if I Can Grab Some images to Post them here....
Old September 27th, 2008   #10 (permalink)
Makes sense. I guess that would put it over the edge. And all in the same pass? I have no idea how they are interacting or what's involved, but at least in archvis, I find that if I need to use more than 4gb, the frames generally take forever and it's worth it to break stuff out into seperate passes. (This way, if just a part of it needs changing, you can render just that pass.) I'd especially assume that this would be true when calcing hair. Seems like a pretty finicky thing, and short of pro films, most of the 3d hair I've seen has been less than perfect (meaning it could have benefited from a little more tweaking by the artist and therefore, another pass). Can't imagine 12 people with cloth and hair all in the same scene! If it looks good, I'll have to give you some serious props.
(Now I'm extra curious to see what you're working on.)
joel burbage
strivestudios
3D Studio Max & finalToon question missheartbeat finalRender 1 January 8th, 2008 02:25 AM
1.5 final HAS BEEN RELEASED tdarcy VRay Render 13 August 9th, 2007 11:24 AM
Weird Render Error?? AFK_Matrix 3ds Max 2 May 9th, 2007 04:34 AM
question regarding making previz render pradipta General Discussions 2 July 24th, 2006 07:55 AM
final render and RPC alex3d finalRender 3 November 11th, 2004 08:31 AM
