Old September 30th, 2008   #1 (permalink)
United Kingdom  Send a message via MSN to emma_firbank
Default
please give your honest opinion to the image attached.
I am new to Vray Render and having trouble with getting the lighting effect i desire, i would welcome any suggestions...
in the scene i currently have a vray plane for the window, and two vray spheres in the scene...
im not using hdri as it wouldnt effect the interior, nor photometric lighting (still researching into settings).
Also, i'm having trouble with the chair leather material.
*thank you for your response, im sorry i've not been able to reply back, i keep getting message about 10 threads and spam... I expected my setting was incorrect.
I am using gi.. primary bounce is set to (1) and irradiance map, secondary (0.75) Light chase. with GI Caustics i have refractive selected and post-processing settings at sat (1) contrast (1.4) contrast base (o.5)
Last edited by emma_firbank; September 30th, 2008 at 08:31 AM. Reason: cant reply back to threads
emma_firbank is offline
Old September 30th, 2008   #2 (permalink)
IC
IC's Avatar
Scotland
Default Re: trouble with vray lighting...
Hi Emma,
Nice image. I'm not sure what the problem is with the lighting apart from it maybe being a bit cold.
A bit more light strength and warmth and it would look great.
The bump on the floor seems to be misaligned with the color map.
Oh and how did you do that towel? Is it a clip map?
http://iainc.carbonmade.com/
IC is offline
Old September 30th, 2008   #3 (permalink)
STRAT's Avatar
Wales
your shadows are very dark too. this can be controlled using colour mapping.
STRAT is offline
Old September 30th, 2008   #4 (permalink)
are you using GI (global illumination)? The shadows are very dark, which suggests that ur not, and you'll find it looks a lot more realistic with lighter shadows.
james_moon is offline
Old September 30th, 2008   #5 (permalink)
Name: Mark Frankmann
Agree with the above. I think it looks pretty good. What is the lighting effect that you desire? Possibly try using Reinhard color mapping with burn .8 or less. Maybe add a slight bit of color to the lights.
The joints in the floor material are distracting to my eye, maybe make them narrower, darker and recessed a little bit.
Look on vray-materials.de for a (free) leather material. Modify it to suit your lighting etc.
Hope this helps.
Mark Frankmann
Open Range Imaging
www.openrangeimaging.com
markf is offline
Old September 30th, 2008   #6 (permalink)
FlytE's Avatar
Name: Andy Pennington
Scotland
Nice image! Personally I wouldnt have caustics on unless there was a specific reason (like you wanted accurate liquid caustics, or you were doing a closeup of a solid glass object). Also I wouldnt make the secondary bounces 0.75... but thats just personal
If you are having trouble getting light under some objects, sometimes setting up an invisible white plane at an angle can help 'bounce' light underneath it. Maybe if you post the rest of your setting someone might be able to help you further.
Good work though.
"How many polygons does the real world push?"
FlytE is offline
Old September 30th, 2008   #7 (permalink)
St Lucia
hi i must say i am impressed with your images especially your exteriors. i am an architect from the caribbean who is into the arch viz business. one question did you use 3dmax and vray.
regards
Dexter
dfdesign is offline
Tags
vray shower room
Vray lighting puttyface VRay Render 8 March 14th, 2008 05:43 AM
Vray Sun/Sky Lighting Malonec Work in Progress (WIP) 6 February 8th, 2008 10:41 AM
Vray for Dummies? I need help with this interior 3DIFX VRay Render 9 November 26th, 2007 08:20 PM
vray exterior lighting trouble frank1331 VRay Render 1 June 24th, 2005 07:24 AM
Vray Interior Lighting charbroil General Discussions 3 November 11th, 2004 07:27 PM
