Old September 30th, 2008   #1 (permalink)
Singapore
Default Dell Optiplex 755
Hi,
I need advise. looking to buy small but yet powerfull enough to handle 3d works (mostly architectural) i came off ebay with this optiplex 755
Processor:
Intel Core 2 Duo E6550 2.33GHz, 4Mb cache
RAM:
8Gb DDR2 800MHz memory - (4 x 2Mb sticks)
Hard disk:250Gb SATA disk
Graphics:
256Mb Radeon 2400XT VGA low profile dedicated graphics card!
Operating system:
Vista business 64bit (free downgrade to XP professional 64bit)
Thanks all,
fly_
3plexs is offline
Old September 30th, 2008   #2 (permalink)
AJLynn's Avatar
Default Re: Dell Optiplex 755
Well, it's got a lot of RAM and 64 bit. The CPU is not good by today's standards and neither is the video card.
AJLynn is offline
Old September 30th, 2008   #3 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
with this PC to down(up)grade to XP ( i have done it to several of this model) you need to have the SATA drivers unique to this machine, search google and you will learn more and find those drivers and people talking about how to make it work with the F6 on install method.
Antisthenes is offline
Old September 30th, 2008   #4 (permalink)
The processor is ok. The real down side is that you are unable to overclock the processor to get more out of it, unless you can successfully use SEtFSB, which some Dells can do.
The gfx card will be an easy upgrade, but make sure the power supply can support it.
I am curious to the price you can get it for?
Slinger is offline
Old September 30th, 2008   #5 (permalink)
i agree about the gfx card 100% but the processor is fine. I actually have the same proc in my workstation at work and it renders fine. It isn't extremely fast, but that will be fixed when Podium 2.0 comes out( We use Podium for are renderings---the draw back now is it is only a single core application.) Then again, I guess it all depends on the type of work load for each individual...based off the OP's use, I think the proc would be fine.
Slinger is offline
Old September 30th, 2008   #6 (permalink)
Belgium
i have seen optiplex 755s for as low as 150$
Old September 30th, 2008   #7 (permalink)
With the spec's the Op mentioned, I doubt it...I was trying to determine if for the OP's sake, if he got it for a good deal, that it would be worth it in regards to gfx card upgrade.
Slinger is offline
Old September 30th, 2008   #8 (permalink)
Belgium
the reason i suspect that go for so cheap is because of the issues with them having a unique issue with XP, besides that's how Craiglist goes, under valued on everything.
Old September 30th, 2008   #9 (permalink)
Singapore
hi,
thanks for feedback, it was listed 495 pounds on ebay. i wonder is there any small case pc but yet powerful enuff to get everything done? dell precision is too heavy and big for me.
regards.
fly
3plexs is offline
Old September 30th, 2008   #10 (permalink)
AJLynn's Avatar
You'll need to look around for what's available in your market but I'd never spend that much on a PC that weak. It doesn't have to say "workstation" - a PC built for gamers can be just as good.
AJLynn is offline
Vista vs. XP with 3ds Max Mkay Hardware and Technical Discusions 11 January 11th, 2008 05:37 PM
Dell UltraSharp 20.1-inch Wide Aspect LCD Eric Hardware and Technical Discusions 4 September 7th, 2005 09:30 AM
Dell laptops AC adapters recall Ernest Burden Hardware and Technical Discusions 0 October 8th, 2004 11:59 AM
