Old October 10th, 2008   #1 (permalink)
Name: Mark Frankmann
Default Mountain Home Interior
I had this in the WIP section. I incorporated the helpful suggestions that were offered there and changed some of the materials around per the architects direction. Here's the finished rendering.
http://www.openrangeimaging.com/test...n_Living01.jpg
any comments or critique will be very much appreciated.
Regards,
Mark Frankmann
Open Range Imaging
markf is offline
Old October 10th, 2008   #2 (permalink)
Aaron Waller's Avatar
Default Re: Mountain Home Interior
Nice Start, some of the textures are causing me problems. Specifically the fireplace, Keep up the good work.
Aaron Waller
CG Artist
Artist Rendering, LLC
http://www.artistrendering.com
Aaron Waller is offline
Old October 10th, 2008   #3 (permalink)
Name: Kittituch Nakaprawing
Thailand
your wood material look so realistic but, I think may be it should be a little bit more glossy reflect.
perspectivo3d is offline
Old October 10th, 2008   #4 (permalink)
Horhe's Avatar
Nice image Mark, that fireplace needs reworking, it spoils the image a little...
Horhe is online now
Old October 10th, 2008   #5 (permalink)
I'm assuming it's the stone texture of the fireplace that you are all finding objectionable. The texture map is a photo I took of some stone work on a building that the architect wants to duplicate. A very rough, unshaped stone, with mortar smeared around. The texture map itself looks like it should. I made a black and white version and used contrast to make a bump map. I have used that in the Vray displacement modifier map slot. I have the displacement pretty low, like 0.5". It has a definite impact on the appearance and I'm thinking that map might need to be re-worked. It seems to be causing it to look like a bunch of noise is being applied all over the stone. The architect seems to like it just fine but I will try a revision based on your comments.
Thank you!
Regards,
Mark Frankmann
Open Range Imaging
markf is offline
Old October 10th, 2008   #6 (permalink)
shaneis's Avatar
The stonework looks OK, it's the flames that look incorrect - flames don't have black edges. Also, there would be an orange glow on the back of the fireplace, maybe some soot too.. You could fix all this in Photoshop, no need to re-render. Maybe soften the shadow edges on the leather couch too. A small blur brush in Photoshop should do it.
All in all, a nice image.
S.
shaneis is offline
Old October 10th, 2008   #7 (permalink)
Shane, excellent observations and dead on. Thanks!
Regards,
Mark Frankmann
Open Range Imaging
markf is offline
Old October 11th, 2008   #8 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
I am uncertain about the camera angle and lens used. I think the lens might be around 160-200mm, but I am not sure if it is the changing angles of the space that are causing that, and not the actual lens. I would need to look at the plan. I don't think you need to drop all the way to a 28, but I think you could use about a 50, and not get all distorted, but nt feel so foreign to the space you are doing the rendering in.
I think part of the problem I am seeing is that the high mm lens makes the furntiure look small in scale.
I am always open to eating crow if I am wrong.
travis schmiesing
crazy homeless guy is offline
Old October 11th, 2008   #9 (permalink)
kippu's Avatar
good image .. i like the mood and that wood
www.renderviz.com
kippu is offline
Old October 11th, 2008   #10 (permalink)
Travis, thanks for your comments! The camera focal length is 28mm. The camera is actually a bit outside of the building using clipping planes. It's a difficult plan to describe. Kind of a series of different sized trapezoids arrayed around a radius in a somewhat staggered fashion. Most with different roof heights and pitches. It was difficult to come up with an angle that achieved the clients wants. The client/architect is pleased with this and now wants another one looking into this part of the house from outside the dining area (where the backs of the chairs are). I'm psyched to do that and grateful to have any work considering the situation.
Kippu, thanks for the encouraging remark!
Regards,
Mark Frankmann
Open Range Imaging
markf is offline
Mountain Home Interior markf Work in Progress (WIP) 5 October 2nd, 2008 09:59 AM
Jeff's 2008 Travel Itinerary Jeff Mottle Travel Forum 6 July 13th, 2008 09:31 AM
interior home library nazcaLine General Discussions 5 June 25th, 2007 06:39 PM
Simple Home Interior mohamad Finished Work 5 May 29th, 2007 02:08 AM
Mountain Home vpii@vpii.com Finished Work 4 July 24th, 2006 12:12 AM
