Go Back   CGarchitect.com > CHALLENGES > The Unchallenge
The Unchallenge A forum for "unchallenges" where users can post models or an idea so that the group can work together to solve the problem, develop new techniques and share thoughts about a particular topic. Kind of like a challenge but without a deadline.
Old January 12th, 2003   #1 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Hi all,
Ever wanted to change the look and feel of an image after it's been rendered? I guess so!
Image manipulation programs are widely used for this goal but have you ever passed beyond the look of a default filter? Well here is your chance to do so!
This is the deal: I supply an image, YOU try out different combinations of filters, blendingmodes, software or whatever it takes to give the render a different look (digitized, stylish, painted,...)
Best of luck!
nisus
Here is the image:
And here are a few results of mine using ps7 solely.
test02
test03
test04
nisus is offline
Old January 12th, 2003   #2 (permalink)
Hi nisus,
You´ve gotten some great results.
I really enjoyed the test03, it reminds me an old watercolor rendering. I love well executed watercolor renderings!
Did you keep track of the steps used to get that result? Next time, try it with a larger rendering with trees, cars and people and show us your results.
"See" you later.
Christian Miranda is offline
Old January 12th, 2003   #3 (permalink)
nisus's Avatar
Belgium
Hi Christian,
Tnx for your kind words on the results.
In test 03, I was actually going for that old pencil and butterpaper look, although this is a stripped down version from my original action (which contained more line/edge jitter).
All commands are recorded in actions, so I can apply them to other images with just a click.
Larger renderings do have some problems because of the fixed pixelbased scale of the filters...
here is a more watercolorlike image... test 05
Be sure to make some tests too!
rgds
nisus
nisus is offline
Old January 13th, 2003   #4 (permalink)
archkre's Avatar
Argentina
This is my version from your small file.
All the post-processing took 3.5 minutes
'Back in the young fatherland'
archkre is offline
Old January 13th, 2003   #5 (permalink)
archkre's Avatar
Argentina
But as I told you , this kind of post is useless,if we just show images without any explanation or explaining what we do.
Regards
archkre is offline
Old January 13th, 2003   #6 (permalink)
nisus's Avatar
Belgium
Hi archkre,
Not really. The idea is to get a bunch of different styles that can be used for reference, not to make identical replica's.
One can always supply more details if one wants to. This can be a step to step explanation or just a wider discription of the technique, e.g. highpass filter in overlay BM or whatever...
Btw, I like your image, especially the sky. Is that the same process you used on your previous post of that house?
rgds
nisus
nisus is offline
Old January 14th, 2003   #7 (permalink)
archkre's Avatar
Argentina
First I had to highly resample your image with no loss, taking it to something like 3.000 x something
with the technique of incremental 10%'s,sharpen & fading in each step.
Afterw. big unsharp: about 300, increase saturation and then the usual.
Cheers!
archkre is offline
Old January 14th, 2003   #8 (permalink)
hi nisus,
lots of blending modes (highlights, midtones and shadows), transparencies, and gradients ....
best to you,
nuno
.Best Regards
.Nuno
nuno is offline
Old January 18th, 2003   #9 (permalink)
nisus's Avatar
Belgium
Hi archkre,
--> you should have asked for a lossless tga or tif
rgds
nisus
nisus is offline
Old January 18th, 2003   #10 (permalink)
nisus's Avatar
Belgium
Hi nuno,
I only see a large gray void... can't see any images ;-(
rgds
nisus
nisus is offline
