Name: Georgina Sallery |
Hi,
I am just starting out and wondering whether anyone has got anyt tips on how to get your first client for an architectural project. I have been using C4D for the past 6 months and architectural renderings is what I would like to specialise in. Do you need to present them with a portfolio? if so how many images and do they all have to be architectural (I assume)? I know it's a bit premature to ask this but what sort of pricing (for starters) is recommended - I know this is a little difficult to answer as you have no image to go by - (quality of work). I am working on my first interior scene at the mo and will post for critique. Another important question is it vital that you have AutoCAD? I've heard you can use Illustrator to tidy up files then use your 3D package and extrude? I would eventually get AutoCAD LT but for the meantime will Illustrator and C4D do? |
Name: Stephen Leworthy |
no, it's not vital you have autocad. it's certainly a help, even acadLT, as if firms want to give you info they generally have acad themselves, so expect DWG's. (better than DXF format). you can ask them for different formats, but always go on the assumption that clients are rather dull, and need straight forward methods.
AcadLT is pretty cheap, and will allow you to view a 3d model with limited (but enough) editing/cleanup facilities. C4D with illustrator is fine. C4D by itself is fine, providing ur a skilled C4D modeller. Personally i model in acad, then render in C4D. The best method of getting work is to produce a strong portfolio, preferably in hard copy format. send firms copys, tell them how wonderful you are, how they cant afford to be without you. AND DONT OVER-CHARGE! even if the first couple of jobs are for peanuts. here's a usefull site listing uk architects - http://www.ribafind.org/ Last edited by STRAT; March 8th, 2004 at 07:05 AM. |
tip for start...well
Make a check list of the investment you did so far, speak with an expert that help you to settle a professional status, find a way to facturate.. make a price list, do also a portfolio, 20/30 images.. persentation card.. there you go.. to the phone, get a list of archi around, start to phone, first to the very far ones, to help you improve a speach, then to the ones you can after pass and leave you're price list and show them you'r portfolio... can be a way... |
Name: Iain Collins |
I agree with the above advice but going in TOO low can cause problems as the client will want to stay with you because you're so cheap.
It's then very difficult to raise your prices and even though the repeat business is good, it will take an age to make money. Another tip is don't be that keen that you give unrealistic timescales. Three all nighters in a row and you'll want to work at McDonalds. |
#7 (permalink) | |
There is a question that I posted as a seperate thread which must be sensitive - about interior content - I only wanted to know whether artists model all their furniture from scratch which I enjoy, but I'm worried that it will add extra time on a project. Any suggestions/comments?
a few places where u can get FREE or BUYable 3d stuff
http://3d-station.com/Tutoriaux/tutoriaux.php?id=91 http://www.abscissa.net/ http://www.autodrop.net/ http://cben.net/ http://www.3dcommune.com/ http://www.hivemindcreations.com/home.html http://www.aeccontent.com/article-00.htm http://www.marvin.com/products/produ...6310EE0F463FFD http://www.point-idrop.com/ http://www.scottonstott.com/Designer.../catalog1.html http://www.viziwiz.com/downloads.html have fun & good luck 4 dat new carreer
